EAGLE User Support (English) F/B annotation severed
  • Views 2612 views
dan3460
dan3460 over 9 years ago
I have just started working in Eagle and came to the problem above. I had for gotten to add a capacitor and I thought that I could added on the schematic and would move to the board. It is possible that being on the board and reshaping the board dimensions I had deleted one the air connections, I don't know. How do I make the board take the changes on the schematic? I looked on line and people only talks about what it means but not how to solve it.
  • dan3460
    0 dan3460 over 9 years ago in reply to autodeskguest
    Maybe is just easier to delete the board and start again, I only changed the size of the board and placed some of the parts.
    Thanks for the replay.
    0 autodeskguest over 9 years ago
    https://www.element14.com/community/message/211759
    Hi
    From the manual you have, found in the folder "Documentation"
    "If you have, however, once edited the board or the schematic
    separately, the
    Electrical Rule Check (ERC) will check the files for consistency when
    they are
    loaded. If inconsistencies are found, the ERC opens an Error window with
    appropriate messages about the Schematic and the Layout. Section 6.12,
    starting with page 195, shows how to proceed in such a case."
    Also the Cadsoft site has a FAQ that provides the initial insight.
    "Board and Schematic are not consistent! What can I do?"
    https://cadsoft.io/support/faq/
    In essence you will need to undo the changes made when the schematic and
    board were not open together.
    Open both schematic and board
    Run the ERC check. It will list lines where it finds a mismatch. Alas
    you will need to decode what each error line is telling you.The look a
    bit cryptic
    Fix the error and run the ERC again.
    You should be able to make all the changes in the schematic but
    appreciate that if you removed something in the board then you will need
    to delete it in the schematic to be rid of the error.
    If you added something in the schematic you will need to delete it so
    that it now matches the board and then add it again whereupon it will
    appear in both the schematic and board.
    All the best
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
