EAGLE User Support (English) Gerber question
  • Views 656 views
Gerber question
jinjinjoe
jinjinjoe over 9 years ago
When running gerb274x-milll-drill.cam, I get a warning:  "layer Drills is active but layer Holes is not active.  Is this OK?"
I imagine it's not OK, but don't know.  How do I get the Holes layer active?
It is one of the viewable layers on the PCB, so that's not the issue.
    0 autodeskguest over 9 years ago in reply to omega-5
    On 05.01.2017 10:30, Friedrich Bleikamp wrote:
    Am 05.01.2017 um 09:33 schrieb Morten Leikvoll:
    Drills cover via and pads. Holes cover non plated holes (drawn with the
    hole command). I guess the default .cam jobs have them both generated
    into one file,
    No, gerb274x-milll-drill.cam has files for plated holes in
    <boardname>.dpv and none plated holes in <boardname>.drh
    Freundliche Grüße / Kind regards
    Friedrich
    Ah right, thanks. I never used that .cam so I was just assuming it
    behaved like the excellon.cam. We can only speculate where that warning
    comes from, but it originates from a time where holes were holes, plated
    or not. You can ignore it at will..
  • omega-5
    0 omega-5 over 9 years ago in reply to autodeskguest
    into one file,
    .drh
    Friedrich
    ... use NNTP://news.cadsoft.de and a
    functional news reader like Thunderbird!
    ... or http://www.eaglecentral.ca
    browser access to CadSoft EAGLE support forums.
    into one file, but my personal .cam version separate plated holes and
    non plated holes into separate gerbers, at the cost of this annoying
    message.
