EAGLE User Support (English) need eagle 7.6 library for 470, 680 or 1000uf 50v cap
  • Subscribers 187 subscribers
  • Views 1191 views
ejeyaseelan
ejeyaseelan over 9 years ago
hey all,
looking for 470uf or 680uf or 1000uf 50v smd capacitor library from nichicon or panasonic or vishay or similar.
any suggestions or help would much appreciated.
looking to source the part thru element14 or digikey
thanks
    0 autodeskguest over 9 years ago
    Look in RCL.LBR for polarized caps. CPOL-EU has european style symbols, and
    CPOL-US has US style symbols. The part # describes the cap's lead spacing
    and diameter. For example, CPOL-USE2,5-5 is a US style cap, with a 2.54mm
    (0.1") lead spacing and a 5mm diameter. Lots of other caps are available in
    the library. Picking a part is a matter of seeing what the vendor has, and
    if there is a matching EAGLE library part. You can also make your own
    library part or modify an existing one.
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
