EAGLE User Support (English) Cut-able link/jumper part that does not logically short nets.
  • Views 583 views
  • errors
  • jumpers
  • link
BillyBag2
BillyBag2 over 9 years ago
Can I make a link or jumper part with cut-able copper between the two pads that does not cause an error? Perhaps create a layer for the cuttable copper and add it to the copper layer at export time.
    0 autodeskguest over 9 years ago in reply to BillyBag2
    William Bagshaw wrote on Mon, 30 January 2017 12:53
    OK, searched for more on this. I don't think it is possible. Two
    alternative seam to be in common use. First design a part that shorts the
    two pads and then deal with the error. The second is use a 0R approach. I
    think for what I want to do I will use a tiny 0R part and just blob
    solder across it. I was hoping for something better. As I said, art
    working the short into another layer and then combining it on output
    would do, if I knew how to do this.
    Hi William,
    You can absolutely do what you are wanting to do, I've done it many times.
    Let's say you have a 2-layer board.  Set up the DRC->layers tab for 3
    layers.  Then use the 3rd layer for your copper jumpers.  By using an
    electrical layer the ratsnest tool will take these into account so you know
    that all nets are routed. (If you use a non-electrical layer ratsnest won't
    know about them).
    Then, in the CAM processor, include the 3rd layer in the section where you
    want it included (top or bottom gerber).  This will "OR" your jumper layer
    into the layer in question.
    IMPORTANT NOTICE :  With this method the PCB DRC tool won't catch any
    unintentional shorts between the 3rd layer and the layer you merge it into!
    So you can end up with unusable boards if copper overlaps in places you
    don't intend.  The good thing is you can manually inspect the gerbers and
    know if you have an issue or not.  But you have to be very careful.
    Hope that helps.
    Cheers,
    James.
    http://www.stratforddigital.ca
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • BillyBag2
    0 BillyBag2 over 9 years ago
    OK, searched for more on this. I don't think it is possible. Two alternative seam to be in common use. First design a part that shorts the two pads and then deal with the error. The second is use a 0R approach. I think for what I want to do I will use a tiny 0R part and just blob solder across it. I was hoping for something better. As I said, art working the short into another layer and then combining it on output would do, if I knew how to do this.
