EAGLE User Support (English) Set >LAST_DATE_TIME format to yyyy-mm-dd
  • Subscribers 187 subscribers
  • Views 437 views
  • eagle
  • format
  • last_date_time
  • time
  • date
nurmichl
nurmichl over 9 years ago
We need to change the date/time format into ISO8601 format (yyyy-mm-dd)
I tested our eagle start-script with several lang-variables, but nothing worked correct for me.
We use eagle 7.3.0 on a Gentoo Linux System.
#!/bin/bash
# this is startEagle.sh
lang="en_US" LC_TIME="en_DK.utf8" /opt/bin/eagle
We also tried to modify the time-description in /usr/share/i18n/locales/en_US
echo -n %Y-%n-%d | hexdump -v -e '/1' "<U00%02X>" ; echo
and reboot with this modified lang-settings.
Is there a way to set the date-format in the correct way?
    0 autodeskguest over 9 years ago
    On 1/31/2017 7:31 AM, Michl Neumayer wrote:
    We need the date/time of the last change in ISO8601 format (yyyy-mm-dd)
    #!/bin/bash
    1. this is startEagle.sh
    https://www.element14.com/community/message/214829
    Hello Michl,
    I hope you're doing well. I've put in a an enhancement request for this,
    at this point in time the only solution is to manually add in the date
    using the TEXT command.
    Best Regards,
    Jorge Garcia
