EAGLE User Support (English) Routing board manually, trace will only start at inrouted point.
  • Replies 16 replies
  • Subscribers 191 subscribers
  • Views 2192 views
jelbert
jelbert over 9 years ago
While routing a board, the unrouted (wire unrouted) connections are shown with thin lines.
In the beginning of the board these lines are logical and it helps routing the board. But I can only start a new trace at the point where these thin lines start.
At this example I want to start routing at the end of the GND trace. But the router will not allow me to do that. The workaround is to delete the trace to the point of the unroute and then continue from there. In this case that is not much extra work. But sometimes I have to delete quite a lot until I can continue.
There must be a setting somewhere to disable this 'feature' and let me route from any point I want. But how?
I use Eagle 7.7 Premium.
    0 autodeskguest over 9 years ago
    Jelbert Holtrop wrote on Tue, 07 February 2017 10:07
    start.
    This is simply not true, as reading the help for ROUTE would have revealed.
    If you hold down CTRL when left clicking on a location to start routing,
    it starts from there, not the nearest airwire end.
    Again, this is all described in the help right where you'd expect to find
    it.  Some times it can be difficult to find things in the Eagle help when
    you don't know enough to know what to ask, but in this case it is very
    clearly documented.  In fact it's the first option show for the ROUTE
    command.  READ THE MANUAL already!
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    start.
  • omega-5
    0 omega-5 over 9 years ago in reply to jelbert
    Am 07.02.2017 um 16:53 schrieb Jelbert Holtrop:
    But it can not be true that this is the only way to route a trace! I used other routing software ,Mentor Graphics Pads, and never had this kind of problem. There you had the same lines. But when clicking on a net the line would jump to that place on the net and routing would start from that point.
    Eagle has the great advantage of the ULP language and the use of eagle in the Open Source community.
    https://www.element14.com/community/message/215354
    HELP ROUIE -
    Ctrl+Left starts routing at any given point along a wire or via.
    Freundliche Grüße / Kind regards
    Friedrich
    ... use NNTP://news.cadsoft.de and a
    functional news reader like Thunderbird!
    ... or http://www.eaglecentral.ca
    browser access to CadSoft EAGLE support forums.
  • omega-5
    HELP ROUIE -
    Friedrich
  • jelbert
    0 jelbert over 9 years ago in reply to c4m4ch0
  • c4m4ch0
    0 c4m4ch0 over 9 years ago
    Hi, I usually do the same and delete a part of the net and start routing again there but when it cames to gnd, normally I use the polygon tool to do a gnd plane to save me time instead of trace all the grounds. Also its quicker to etching the pcb and keep your circuit more immune to interference.
