EAGLE User Support (English) Eagle Command Line Name for Net
  • Views 1575 views
  • eagle
  • name
  • command
  • net
romaindelamea
romaindelamea over 9 years ago
Hi !
I'm looking for a command line to name a Net.
To name a part, I write "NAME OLD_NAME NEW_NAME (for example : NAME IC1 UC, IC1 is the name automatically given and UC the new name I want.
But this command does't work with NET. When I write NAME N$1 SPI_CS to name the NET N$1 "SPI_CS" I get an error : Eagle doesn't know the part N$1 !
I've tried with command "NAME 'NET: N$1 SPI_CS" ('NET: N$1 is wrote on the bottom of the eagle windows) but it doesn't work too image
Does anybody has an idea of what command use ?
Tank's for answer and have a good day !
Romain.
PS : Sorry for my bad English, I'm a french user image
  • rachaelp
    0 rachaelp over 9 years ago in reply to autodeskguest
    Hi Lorenz,
    Yes that's a good point! I didn't bother checking as I only ever use inches
    in schematics but yes, using the explicit units in the coordinate
    formatting is the correct thing to do. Thanks for pointing this out.
    Best Regards,
    Rachael
    P.S. Sorry for the messed up code presentation on NNTP / EAGLE Central, I
    posted my original reply on Element14 and it seems code sections don't come
    over to these places well at all....
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    0 autodeskguest over 9 years ago in reply to rachaelp
    rachaelp wrote:
    Yes you can't use the NET command in that way although you can work around it with a simple ULP.
                         sprintf(tmp, "NAME %s (%f %f);", argv[2],u2inch(W.x1),u2inch(W.y1));
    one small modification here. You either need to make sure your grid
    setting matches the coordinate conversion function, or use explicit
    units in your coordinate formating.
    Something linke:
    :  sprintf(tmp, "NAME %s (%fin %fin);", argv[2],u2inch(W.x1),u2inch(W.y1));
    or
    :  sprintf(tmp, "NAME %s (%fmic %fmic);", argv[2],u2mic(W.x1),u2mic(W.y1));
    Lorenz
    Something linke:
    or
    Lorenz
    Something linke:
    or
    Lorenz
  • rachaelp
    Hi Romain,
    Copy the following into a file called nameNet.ulp and put it into your ULP folder:
    // Define variables
    string cmd="SET CONFIRM YES; ";
    if (schematic) {
       schematic(S) {
          S.sheets(SH) {
             SH.nets(N) {
                string tmp;
                if (N.name == argv[1]) {
                   N.segments(SEG) {
                      SEG.wires(W) {
                         cmd += tmp;
    cmd += "SET CONFIRM OFF;";
    exit(cmd);
    now issue the following command:
    run nameNet OLD_NAME NEW_NAME
    You should find that your net gets renamed throughout your schematic.
    Please note: I have NOT fully tested this and it is to be used completely at your own risk.
    Best Regards,
    Rachael
    EDIT: Updated as per comments from Lorenz below.
