EAGLE User Support (English) Multiple schematics question
  • Views 558 views
alberthall
alberthall over 9 years ago
I have created a schematic and board - OK.
I created a second schematic sheet to show the off-board connections but eagle wants to put those components on the PCB.   Is there a way to tell eagle not to include sheet2 on the board?
I know I can create a separate project for this but it would be tidier to include it all in one project.
  • alberthall
    0 alberthall over 9 years ago in reply to autodeskguest
    Thanks for that.  The problem is it would be convenient to use already existing components from the libraries and, as far as I can discover, you can't do 'external' for existing components which have packages.  However, while exploring 'external' with the help of my friend Mr Google I came across the explode.ulp which takes a schematic group and converts it into lines on the info layer removing all electrical stuff and packages.  This absolutely solves the problem.
    Explode.ulp is here: Autodesk Eagle
    0 autodeskguest over 9 years ago
    Hi James,
    if you define the off-board devices, you can use
    the external attrib to flag them as off-board
    (help external)
    HTH
    Werner
    Am 27.03.2017 um 13:33 schrieb James Thurgood:
    https://www.element14.com/community/message/219429
