EAGLE User Support (English) Eagle netlist export problems
  • Subscribers 189 subscribers
  • Views 2137 views
  • netlist
  • eagle 7.6
bberkowi
bberkowi over 9 years ago
I'm trying to export my Eagle schematic as a netlist that is readable by Altium Designer (I use Eagle to develop schematic, contractor uses Altium to do layout). I used the UDP called "netlist_protel.udp", but it looks like a lot of times this UDP for some reason will list the pin connection by the pin's name (ie "U7-ADC7") rather than the pin number (ie "U7-22"). We've also tried Altium's Eagle file importer, and that also creates errors. Does anyone have a better netlist exporter for the purpose of getting a netlist into Altium?
  • bberkowi
    0 bberkowi over 9 years ago in reply to autodeskguest
    This was the way to go. I generated the board from the schematic, exported with the netlist-protel.udp, and everything worked as needed. Thanks!
    0 autodeskguest over 9 years ago
    https://www.element14.com/community/message/221544
    Actually, there is already ulp that generates IPC-D-356A format files
    See if that works.
    ipc-d-356.ulp
    All the best
    Warrn
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
    0 autodeskguest over 9 years ago in reply to rachaelp
    On 3/05/2017 8:25 p.m., Rachael wrote:
    Ben Berkowitz wrote on Tue, 02 May 2017 23:31
    Does the EAGLE importer create the same errors? If not what are they? I
    believe the importer generates some log files which might help give a clue
    as to what else may be going on.
    Best Regards,
    Rachael
    I don't think there are errors as such. Simply the netlist is being
    taken from the schematic and needs to be taken from the board.
    One of the file formats Altium designer could be expecting is IPC-D-356A
    If so then the Eagle ulp export-ict-netlist-pad-coordinate.ulp  would
    appear to have most of the code needed to write a ULP to create a
    IPC-D-356A file.
    The OP should run the ulp in the board which can be created with one
    click from the schematic, no need to lay it out. Then inspect the file.
    you can see it has both the pads and pins for each contact reference.
    HTH
    Warren
    Thunderbird!
    support forums.
  • rachaelp
    0 rachaelp over 9 years ago
    Best Regards,
    Rachael
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • rachaelp
    0 rachaelp over 9 years ago in reply to autodeskguest
    warrenbrayshaw wrote on Wed, 03 May 2017 05:23
    You can make this turn out right for you by renaming the pin names in
    the symbols in the libraries to match the numbering of pins of the
    package.
    That would solve the problem, but would also make the EAGLE library less
    usable as the schematics would be less readable with pin numbers rather
    than names showing. It would get the OP out of a hole if this export is
    needed urgently though.
    The netlist format required probably isn't too difficult so an up to date
    export ULP could be written to do this properly without too much pain I
    would think so long as the format of the netlist is specified somewhere or
    easily derivable for some example files.
    Best Regards,
    Rachael
    Ben Berkowitz wrote on Wed, 03 May 2017 10:31
    The ulp you quote was created in 2001 so I would not expect that to be the
    ulp you would need.
    If no one can help straight away, your next move would be provide the
    format document for what Altium is expecting.
    Your current problem is with pin/pad. In Eagle the board has pads that are
    most commonly numbered, matching the pin numbers of the package. You can
    make this turn out right for you by renaming the pin names in the symbols
    in the libraries to match the numbering of pins of the package. What ever
    you do the Altium numbering of pins/pads will need to match your Eagle
    library numbering so every device will need to be checked.
    HTH
    Warren
