EAGLE User Support (English) My Eagle PCB design generates lines in ground plane instead solid plane !
  • Answers 2 answers
  • Subscribers 189 subscribers
  • Views 1058 views
jitendraprusty
jitendraprusty over 9 years ago
  • jitendraprusty
    0 jitendraprusty over 9 years ago in reply to autodeskguest
    Ok. I've sent the Gerber files to PCB house and let's see what happens. I will let you know the results. Thanks.
    0 autodeskguest over 9 years ago in reply to jitendraprusty
    On 2017-06-07 03:21, Jitendra Prusty wrote:
    Thanks, but all your suggestions were done but the problem is still there, Please have a look at my PCB...
    https://drive.google.com/file/d/0Bz8amWnaXXM0OWtMdGNON0lkNDQ/view?usp=drivesdk
    It looks like this is from a gerber file. Zooming in closer to the board
    will probably make the board look normal. Solid fills are similar to a
    raster fill, so the graphics renderer of the gerber viewer is trying to
    draw each line of the rasterized fill. The gerber itself should be fine
    for fabrication.
    See the attached images for zoom level examples using gerbv showing this
    behavior.
    Eric
  • jitendraprusty
    0 jitendraprusty over 9 years ago in reply to rachaelp
    0 autodeskguest over 9 years ago in reply to rachaelp
    There are a few reasons I can think of that will make this happen or appear to have happened.
    1) You have not run the RATSNEST command to process the polygon.
    2) You have not named the polygon to the correct signal for the ground plane. If this is the case, use the NAME command to rename the polygon.
    3) You do not have anything currently connecting to the ground plane. EAGLE will only process a polygon that has connections to it so as soon as you drop a via to connect to it it will fill.
    4) You drew the ground plane shape with the WIRE tool rather than the POLYGON tool.
    Unless the OP actually means his fill is stripy rather than solid, in
    which case the question is when he's seeing this. Users who print on
    transparency for home etching often report this due to issues with
    printer drivers.
  • rachaelp
    0 rachaelp over 9 years ago
    Best Regards,
    Rachael
