EAGLE User Support (English) When I place pads, they're invisible
  • Views 590 views
  • diameter
  • eagle
  • pads
  • package
  • invisible
s0s
s0s over 9 years ago
I'm creating a package in Eagle 6.5.0 Light, and when I place pads, they're invisible. It happens when I change the diameter of the pad to the diameter of the pins in the device datasheet. How can I fix this? I need to make a schematic for a system I'm designing. The desired diameter is 0.457 mm +- 0.127 mm. Thanks
  • s0s
    0 s0s over 9 years ago
    I discovered that I need to change the drill value. That fixed it.
