EAGLE User Support (English) tcream layer areas missing
  • Subscribers 189 subscribers
  • Views 735 views
exxos
exxos over 9 years ago
I am using Eagle 6.4, and when I export gerber files, it all works as expected, only tcream areas which are not part of actual parts are missing from the gerber export ?
Take for example, if I placed a single SMD capacitor, I would get the 2 pads on the tcream layer, and they would export to gerber as expected. Though if I (for example) added a longer tcream rectangle to the part, then the longer parts would not export.
I know that if I go through all the parts and manually edit the tcream for each part, it would work, but this would take a huge amount of time.  I would have thought eagle would export tcream areas which were manually drawn just like it does on top and bottom layers for example, but it seems not :-(
  • exxos
    0 exxos over 9 years ago in reply to niteowl12
    I was using smtstencil.co.uk , though after chasing my order for 2 months I gave up and ordered from hobbytronics.co.uk. Though they are the ones who need DXF files.
    I did not know osh did stencil as well, so thank for that.  Will see if that can get anywhere with them.
  • niteowl12
    0 niteowl12 over 9 years ago in reply to exxos
    Which place do you use for stencils? Try this site https://www.oshstencils.com/ , They take eagle brd files or gerbers for the stencils.
  • exxos
    Thanks for your thought. The PCB is saved.  If I turn off the tcream layer, then the the whole layer vanishes as expected , even the bits I manually added.  So its all on the right layer. Just Eagle doesn't seem to want to export them image
    Its causing issues as the place I use for stencils needs the eagle file converting to DXF format, they have a ULP script, but that has the same issue as well.  Its ignores all tcream areas added manually.
    I would have thought Eagle itself would actually export the whole tcream layer as is, I don't get why it doesn't :-(
  • niteowl12
    I have had issues getting them to export if I don't save the board before I export. Also make sure they are on the tcream layer and that your cam processor has a tab that processes just that layer. Hope this helps.
