EAGLE User Support (English) How to select all items
  • Subscribers 189 subscribers
  • Views 3599 views
  • eagle 8
  • new library part
gharryh
gharryh over 9 years ago
This morning i felt like a total idiot.
I am in the library symbol editir and wanted to select all as i am used before in version6.
But now in version8 i cant find the menu option to select.
Is it gone or changed its name??
Harry
  • dukepro
    0 dukepro over 9 years ago in reply to autodeskguest
    On 07/03/2017 07:42 AM, Hans Lederer wrote:
    Am 03.07.2017 um 12:57 schrieb rachaelp:
    Hi Harry,
    In EAGLE v8 you can just do CtrlA (CmdA on macOS) to select all.
    In EAGLE v7 (and presumably earlier versions) you just select the GROUP command and then drag a group around everything. I'm not aware of a menu option to just do a select all.
    GROUP ALL
    (everything on all currently activated layers)
    Harry,
    Bear in mind that the "Group All" command does NOT select names and
    values that are not smashed.
    I often use the "group all" command to change all the names to the
    vector font:
    1. Make sure the desired layers are active.
        Disp tNames bNames tOrigins bOrigins;
        Group all;                  # Group everything.
        Smash (C>0 0);              # Smash everything in the group.
        Group all;                  # Group everything including the smashed
        names.
        Change font vector (C>0 0)  # change all fonts to vector.
        Change ratio 15 (C>0 0)     # change all ratios to 15%.
    The C and the > in the coordinates represent a control right-click.
    Since that operates on the selected group, it doesn't matter where the
    click occurs.  "0 0" is just easiest to type.
    Prior to the above, I will make sure that both tOrigins and bOrigins are
    turned on so that all components will be included in the group.  The
    objective of the first "group all" is to select all components - both
    top and bottom.  Then I smash the group, allowing me to select the
    names.  The second "group all" selects the same components as before,
    /and/ the names.
    If you're not familiar with entering coordinates on the command line,
    read section 5.2 of the user manual, or search the manual for "Entering
    Coordinates as Text".  In the 7.7 English manual, it starts on page 95.
    It is worthy to note that both the 'R' modifier and the 'P' modifier
    expect coordinates relative to the mark.  If the mark is not set, it is
    assumed to be the origin.  The difference between these two is that 'R'
    expects rectangular coordinates, and 'P' expects polar coordinates.
    HTH,
        - Chuck
    5226.att1.html.zip
  • rachaelp
    0 rachaelp over 9 years ago in reply to autodeskguest
    Hans Lederer wrote on Mon, 03 July 2017 12:42
    Hi Harry,
    all.
    GROUP ALL
    Hi Hans,
    Yes, and that's what Ctrl+A initiates in v8, but I don't believe that's
    available from a menu option on v7 and earlier. The OP was searching for
    what they thought used to be in the menus somewhere. But you are right,
    issuing that command from the command line is the quickest way image
    Best Regards,
    Rachael
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    0 autodeskguest over 9 years ago in reply to rachaelp
    Hi Harry,
    GROUP ALL
  • rachaelp
    Hi Harry,
    In EAGLE v8 you can just do Ctrl+A (Cmd+A on macOS) to select all.
    Best Regards,
    Rachael
