EAGLE User Support (English) PCB design with external connections.
  • Subscribers 187 subscribers
  • Views 989 views
  • eagle 8
  • pcb board design
rishabhsharma9393
rishabhsharma9393 over 9 years ago
I need to design a PCB with multiple independent components. The connections will be provided externally. How do I make pins/connections in the schematic without getting "Unconnected" errors?
    0 autodeskguest over 9 years ago
    On 13/07/17 00:44, Rishab Sharma wrote:
    I need to design a PCB with multiple independent components. The connections will be provided externally. How do I make pins/connections in the schematic?
    There are three options:
    1)  create a new library for the off-board components, with schematic
    symbols showing their off-board placement somehow. One option is to have
    gaps between the symbol and the pins. Then associate them with packages
    that have the pads you want to connect your wires to.
    2)  Decide on a connector you're going to use for all off-board
    components to hang off. Show this connector on the schematic, with some
    annotation text to explain what's connected to it.
    3)  Just draw the connections using pads, e.g. from testpad.lbr, and
    annotate the schematic. This will allow you to put your wires anywhere
    you like on the board.
    I would probably choose option 1 because, to me, it's by far the
    clearest and neatest. Option 3 is flexible but that leads to ugly
    assemblies.
