EAGLE User Support (English) Which file contains user settings for EAGLE?
  • Replies 11 replies
  • Views 3699 views
  • user-interface
  • settings
SMD111
SMD111 over 9 years ago
I am upgrading from version 6.4 to 6.6 and would like to keep all looks, design rules, etc. exactly the same. What is the best way to do this?
Thank you,
Sergey
    0 autodeskguest over 9 years ago in reply to SMD111
    Am 10.08.2017 um 18:26 schrieb SMD111:
    Hi Joern,
    I cannot find eaglerc.usr file anywhere in the EAGLE 6.4.0 folder.
    Neither it is present in the EAGLE 6.6.0 folder on another computer.
    And the eagle.scr file is a text file that does not seem to contain many settings at all.
    Sergey
    https://www.element14.com/community/message/227003
    Hi Sergey,
    if you haven't edited your eagle.scr file it is the standard coming with
    eagle.
    The eaglerc.usr is most likely in in your user directory that might be:
    (system drive lets say C:) /user / your name / AppData / Roaming /
    Cadsoft / Eagle /eaglerc.usr
    If you can't find it scan the whole computer and/or login as admin.
    This is one of the reasons that I use the U-parameter and store the file
    in a subdirectory of the corresponding eagle version.
    If you just install a new version that place C:( user etc.. will be
    overridden.
    F:\EAGLE-6.6.0\bin\eagle.exe -U F:\Eagle-6.6.0\eaglerc-660.usr
    This is an example that will store the eaglerc.usr (named-600) in the
    eagle main directory of version 6.6.0
    Joern Paschedag
    Hi Joern,
    Sergey
    Hi Sergey,
    eagle.
    overridden.
    Joern Paschedag
    Am 10.08.2017 um 16:48 schrieb SMD111:
    Thank you, Joern!
    One more detail: you say "Remember that newer eagle files cannot be opened with older versions of
    eagle and once you save an 6.4 file with 6.6 it IS converted."
    I did a test installation of 6.6.0 on a separate laptop just to test the new version. I opened an 6.4.0 schematic, modified it a bit, and saved the file. Then I did the same for the board. I took the files to to my PC with the older version of EAGLE and tried to open them. It is true, the schematic does not open. However, the .brd file did open and I could see the modification I had made with the newer version.
    So it looks like only the .sch files are not compatible.
    Sergey
    https://www.element14.com/community/message/227001
    Sorry I wasn't quite clear and mixed something up. image (blush)
    Within the main versions (6.x.x; 5.x.x; 7.x.x) there is actually no
    problem. What I meant is  if you save something with version 7.x.x  i.e.
    and try to open it with version 6.x.x or lower.
    Actually your *.sch should not give any trouble...
    But it's good that you tested it image
    Just give it another try to be sure.
    Joern Paschedag
  • SMD111
    0 SMD111 over 9 years ago in reply to autodeskguest
    Hi Joern,
    Sergey
  • SMD111
    Thank you, Joern!
    Sergey
    0 autodeskguest over 9 years ago in reply to autodeskguest
    Am 09.08.2017 um 21:24 schrieb Rob Pearce:
    On 09/08/17 08:16, Joern Paschedag wrote:
    (Imo U-parameter works only with win)
    No, works fine on Linux too. I use it on the machine with both V4 and V7.
    Ahh, so I learned something new image
    Joern Paschedag
    Am 08.08.2017 um 21:03 schrieb SMD111:
    Thank you,
    Sergey
    https://www.element14.com/community/message/226908
    Hi Sergey,
    there are 2 files to control eagle: the "eaglerc.usr" and the "eagle.scr".
    The last named is in the "scr" subdirectory of eagle.
    I don't know anymore where the "eaglerc-usr" is located, since I use
    that file with the U-parameter in different directories. (I use
    different versions of eagle, that's why image )
    Anyway you can save those files under a different name and replace the
    files after installation of the new version.
    My suggestion: Install 6.6 besides your 6.4 installation if you use
    windows OS.
    Description can imo only be found somewhere in "update_eng.txt" located
    in doc subdirectory:
    "The new command line option '-U' can be used to define the LOCATION  of
    the 'eaglerc' file in which EAGLE stores user settings".
    This is not quite correct, because you can also change the NAME of the
    eaglerc.usr.
    So my "eaglerc.usr" file for version 6.4.0 has the name "eaglerc-640.usr".
    Joern Paschedag
