EAGLE User Support (English) Which file contains user settings for EAGLE?
  • Replies 11 replies
  • Subscribers 180 subscribers
  • Views 3169 views
  • user-interface
  • settings
SMD111
SMD111 over 8 years ago
I am upgrading from version 6.4 to 6.6 and would like to keep all looks, design rules, etc. exactly the same. What is the best way to do this?
Thank you,
Sergey
    0 autodeskguest over 8 years ago in reply to SMD111
    Am 10.08.2017 um 18:26 schrieb SMD111:
    Hi Joern,
    I cannot find eaglerc.usr file anywhere in the EAGLE 6.4.0 folder.
    Neither it is present in the EAGLE 6.6.0 folder on another computer.
    And the eagle.scr file is a text file that does not seem to contain many settings at all.
    Sergey
    https://www.element14.com/community/message/227003
    Hi Sergey,
    if you haven't edited your eagle.scr file it is the standard coming with
    eagle.
    The eaglerc.usr is most likely in in your user directory that might be:
    (system drive lets say C:) /user / your name / AppData / Roaming /
    Cadsoft / Eagle /eaglerc.usr
    If you can't find it scan the whole computer and/or login as admin.
    This is one of the reasons that I use the U-parameter and store the file
    in a subdirectory of the corresponding eagle version.
    If you just install a new version that place C:( user etc.. will be
    overridden.
    F:\EAGLE-6.6.0\bin\eagle.exe -U F:\Eagle-6.6.0\eaglerc-660.usr
    This is an example that will store the eaglerc.usr (named-600) in the
    eagle main directory of version 6.6.0
    Joern Paschedag
