EAGLE User Support (English) Arduino Nano not wiring
  • Views 785 views
  • arduino nano
daredevil73
daredevil73 over 9 years ago
Hi, I have just installed the E14 Arduino library in order to use the Arduino Nano part.
I have got some problems with DRC. I had to reduce to 10 mils the Minimum Distance/Copper/Dimension to avoid Dimension Error in DRC errors check.
Unfortunately, when I try to autoroute my PCB none of the Arduino pins are wired to the other parts.
Then I tried to route manually some tracks, but the Arduino part does not allow to cross the part boundaries!
Could anybody help me?
Thank you so much,
Antonio
  • daredevil73
    0 daredevil73 over 9 years ago in reply to autodeskguest
    Thank youfor you answer.
    I have fixed the part. Please tell me if I can share it with the community, and how.
    0 autodeskguest over 9 years ago
    Hi
    I expect the problem will be in the Arduino Nano part.
    It will have its outline drawn on layer 20 Dimension.
    Edit the library such that the outline of the part is on layer tPlace
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
