EAGLE User Support (English) customizing bom.ulp
  • Subscribers 187 subscribers
  • Views 1752 views
  • eagle ulp
customizing bom.ulp
saurabh564
saurabh564 over 9 years ago
hello sir, warm regards.
I want to ask if the default bill of material (bom) syntax, can be customized. If so how?
For eg. can I generate the following bom syntax.
Thanks in advance..
PFA
    0 autodeskguest over 9 years ago
    On Mon, 25 Sep 2017 12:56:57 GMT, saurabh k
    I didn't see an syntax described in your posting, but you can find the
    bom.ulp file by going to the folder where your eagle program is
    located, going one level up and looking for the "ulp" folder.  There
    you will find all the ULPs, including bom.ulp.  I do not advise you to
    modify that file.  Instead copy that file into a different folder (for
    example the documents\Eagle folder) and then renaming it to something
    like "MyBOM.ulp".  Then edit it with a text editor and make whatever
    changes you want to make.  Then when it comes time to generate the
    BOM, you will have to navigate to this other folder and find you
    "MyBOM.ulp" file and execute it.  Here is my modified BOM.ulp.  It
    extracts data from part attributes named "PNUM".  For example:
    Attribute name:  PNUM
    Attribute value:  Digikey=RN4871-V/RM118-ND
    MyBOM.ulp:
    #require 6.0200
    string Version = "7.00";
    char   Separator = ';'; // 2012-12-04
    #usage "en: "
               "Erzeugt die Stückliste (Bill Of Material) eines
    Projekts, einschließlich der"
               " mit Version 5.0.0 neu eingeführten Attribute."
               "\n"
      "The Bill Of Material can be generated either as a list\n"
      "of parts (where every part is listed on a line of its own),\n"
      "or as a list of values, where all parts with the same value are
    grouped\n"
      "together in one line. Use the
    Parts
    and
    Values
    \n"
    "radio buttons to select the list type.\n"
    \n"
    Output format
    \n"
    \n"
    "Choose between pure ASCII
    Text
    format,
    CSV
    or
    HTML
    .\n"
    string HelpTextDE =
    Erzeugen der Stückliste
    \n"
    \n"
    Listen-Typ
    \n"
    \n"
      "Die Stückliste kann entweder als Liste der Bauteile
    generiert werden\n"
      "(wobei jedes Bauteil in einer eigenen Zeile aufgeführt wird),\n"
      "oder als Liste der Werte, wobei alle Bauteile mit dem gleichen Wert
    in einer Zeile\n"
      "zusammengefasst werden. Mit den Radio-Buttons
    Bauteile
    und
    Werte
    \n"
    "kann zwischen den beiden Listen-Typen gewählt werden.\n"
    \n"
    Ausgabeformat
    \n"
    \n"
    "Wählen Sie zwischen reinem ASCII-
    Text
    CSV
    oder
    HTML
    "-Format.\n"
    string I18N[] = {
    "en\v"
    "de\v"
    ERROR: No schematic!
    \nThis program can only work in
    the schematic editor.\v"
    FEHLER: Kein Schaltplan!
    \nDieses Programm kann nur in
    einem Schaltplan verwendet"
      " werden.\v"
      "Part\tValue\tDevice\tPackage\tDescription\v"
      "Bauteil\tWert\tDevice\tPackage\tDescription\v"
      "Qty\tValue\tDevice\tPackage\tParts\v"      // 2011-04-08
      "Menge\tWert\tDevice\tGehäuse\tBauteile\v"  // 2011-04-08
      "Partlist exported from %s at %s\v"
      "Stückliste exportiert aus %s am %s\v"
      "Bill Of Material - Preview\v"
      "Stückliste - Vorschau\v"
      "-Close\v"
      "-Schließen\v"
      "Save Bill Of Material\v"
      "Stückliste speichern\v"
      "File '\v"
      "Datei '\v"
      "' exists\n\nOverwrite?\v"
      "' existiert\n\nÜberschreiben?\v"
      "+&Yes\v"
      "+&Ja\v"
      "-&No\v"
      "-&Nein\v"
      "&No\v"
      "&Nein\v"
      "Name already defined!\v"
      "Name ist bereits definiert!\v"
      " Header\v"
      " Spaltenüberschrift\v"
      "&Name:\v"
      "&Name:\v"
      "+OK\v"
      "+OK\v"
      "Name can't be empty!\v"
      "Name kann nicht leer sein!\v"
      "-Cancel\v"
      "-Abbrechen\v"
      "&Headers\v"
      "&Spaltenüberschriften\v"
      "Bill Of Material - Help\v"
      "Stückliste - Hilfe\v"
      "Bill Of Material\v"
      "Stückliste\v"
      "List type\v"
      "Listen-Typ\v"
      "&Parts\v"
      "&Bauteile\v"
      "&Values\v"
      "&Werte\v"
      "Output format\v"
      "Ausgabeformat\v"
      "&Text\v"
      "&Text\v"
      "&CSV\v"
      "&CSV\v"
      "&HTML\v"
      "&HTML\v"
      "+Vie&w\v"
      "+&Vorschau\v"
      "&Save...\v"
      "&Speichern...\v"
      "H&elp\v"
      "H&ilfe\v"
      "Current &variant \v"
      "Aktuelle &Variante \v"
      "List &attributes\v"
      "&Attribute auflisten\v"
    int Language = strstr (I18N , language ()) / 3;
    string tr (string s)
      string t = lookup (I18N, s, Language, '\v');
      return t ? t : s;
    if (!schematic)
      dlgMessageBox (usage + tr ("
    \nThis
    program can only work in"
                     " the schematic editor."));
      exit (1);
    string SeparatorString;
    int     NumParts;
    numeric string Lines[];
    numeric string PartName[];
    string  PartValue[], PartDevice[], PartPackage[],
    PartHeadline[],PNum[];
    numeric string PartDescription [];
    int     PartValueOn[];
    int     Selected;
    string CurrentVariant = "";
    string Variants[] = { "" };  // 2012-04-16
    int    cntVD = 0;
    int    VDsel = 0;
    // cwi: Added arrays for an arbitraty number of attributes.
    int UseAttributes = 1;
    int FoundAttributes = 0;            // # of different attribute names
    found in schematic.
    numeric string AttributesList[];    // Sorted list of all attributes
    found in the schematic.
    numeric string PartAttributes[];    // Adjusted list of attributes per
    part.
    enum { ltParts, ltValues };         // List Types
    enum { ofText, ofCSV, ofHTML };     // Output Formats
    int ListType = 0;
    int OutputFormat = 0;
    string StripWhiteSpace (string s)
      while (s && isspace (s[0]))
        s = strsub (s, 1);
      while (s && isspace (s[strlen (s) - 1]))
        s = strsub (s, 0, strlen (s) - 1);
      return s;
    // Collect part data from the schematic.
    // Arguments: -
    // Returns:   NumParts            - # of found parts
    //            ParteName[]
    //            PartValue[]
    //            PartDevice[]
    //            PartPackage[]
    //            PartHeadline[]
    //            PartDescription []
    //            PartValueOn[]      - 0=part value off, 1= part value on,
    2=override with attr. VAL
    //            FoundAttributes     - # of different attribute names
    found in schematic.
    //     PNum[] - extracted from attributes whose name is "PNUM"
    //            AttributesList[]   - Sorted list of all attributes found
    in the schematic.
    //            PartAttributes[]   - Adjusted list of attributes per
    part.
    void CollectPartData (string var)
      int Found = 0;
      int i;
      string attr[];
      NumParts = 0;
      // First, collect the names of all available attributes.
      if (UseAttributes) {
        schematic (SCH)
          SCH.parts (P)
            if (P.device.package)
              if (P.populate)
                P.attributes (A)
                  if (0 == FoundAttributes)
                    // First one
                    AttributesList[0] = A.name;
                    FoundAttributes = 1;
                  else
                    Found = 0;
                    for (i = 0; i < FoundAttributes; i ++)
                      if (A.name == AttributesList[i])
                        // Found an already listed atrribute
                        Found = 1;
                        break;
                    if (0 == Found)
                      // Attribute not listed, add at the end.
                      AttributesList[FoundAttributes] = A.name;
                      FoundAttributes ++;
        sort (FoundAttributes, AttributesList);
      // Second, collect all data
      schematic (SCH)
        SCH.parts (P)
            if (P.populate)
              PartName[NumParts] = P.name;
              PartValue[NumParts] = P.value;
              PartDevice[NumParts] = P.device.name;
              PartPackage[NumParts] = P.device.package.name;
              PartHeadline[NumParts] = P.device.headline;
              PartDescription = P.device.description;
              PartValueOn[NumParts] = P.device.value == "On";
              // Zero all strings
                   attr[i] = "";
         PNum[NumParts] = "";
              P.attributes(A)
                    attr[i] = A.value;
                    //break;
              if(A.name == "PNUM")
                   PNum[NumParts] = A.value;
                if ("VALUE" == A.name && 0 < strlen (A.value))
                 // Override old fashioned value information!
                PartValueOn[NumParts] = 2;
              PartAttributes[NumParts] = strjoin(attr, Separator);
              NumParts ++;
    void GeneratePartList(void)
      int NumLines = 0;
      string attr[], s;
      if (UseAttributes) s = strjoin(AttributesList, '\t');
      Lines[NumLines ++] = tr ("Part\tValue\tPackage\tPart Num");
      for (int i = 0; i < NumParts; i ++)
        strsplit (attr, PartAttributes[i], Separator);
        if (UseAttributes) s = strjoin(attr, '\t');
        Lines[NumLines] = PartName[i] + "\t" + PartValue[i] + "\t" +
    PartPackage[i] + "\t" +
                           PNum[i];
        NumLines ++;
      Lines[NumLines] = "";
    // Generate list with one entry per value.
    // 'VALUE' is replaced by the value of attribute 'VAL', if existing.
    void GenerateValueList (void)
      int NumLines = 0;
      int Index [];
      string attr[], s, s_val;
      // 2010-04-17 cwi: Included description.
    ("Qty\tValue\tDevice\tPackage\tParts\tDescription\t") + s;
    // 2011-04-08
      sort (NumParts, Index, PartValue, PartDevice, PartPackage,
    PartAttributes, PartName, PartHeadline); // 2011-11-08 Partattribute
    jetzt nach Package alf@cadsoft.de
      for (int n1 = 0, n2 = 0; ++ n2 <= NumParts; )
        int i1 = Index ;
        strsplit (attr, PartAttributes[i1], Separator);
        s_val = attr[i1];
        if (n2 < NumParts)
          int i2 = Index ; // 2012-11-08
          strsplit (attr, PartAttributes[i2], Separator);
          if (PartValue[i1] == PartValue[i2] && PartDevice[i1] ==
    PartDevice[i2] && PartAttributes[i1] == PartAttributes[i2]) //
    2012-11-08 check diffent values of attributes
            continue;
        string Quantity;
        sprintf (Quantity, "%d", n2 - n1);
        Lines[NumLines] = Quantity + "\t" + PartValue[i1] + "\t" +
    PartDevice[i1] + "\t" + PartPackage[i1] + "\t";
        for (;;)
          Lines[NumLines] += PartName[i1];
          if (++n1 < n2)
            i1 = Index ;
            Lines[NumLines] += ", ";
          else
            break;
        // cwi: add extra information from attributes
        Lines[NumLines] += "\t" + PartHeadline[i1] + "\t" + s;
        NumLines ++;
    void GenerateList (void)
      switch (ListType)
        case ltParts:  GeneratePartList (); break;
        case ltValues: GenerateValueList (); break;
    string MakeListHeader (void)
      string s;
      schematic(SCH)
        sprintf (s, tr ("Partlist exported from %s at %s"), SCH.name,
    t2string (time ()));
      return s;
    string MakeListText(void)
      int l, Width [];
      string List;
      int numHeaders;
      for (l = 0; Lines[l]; l ++)
        string a [];
        for (int n = strsplit (a, Lines[l], '\t'); n --; )
          Width = max (Width , strlen (a ));
      List = MakeListHeader () + "\n\n";
        string line, a [];
        if (l == 0)
          numHeaders = n;
        else
          n = numHeaders; // for the hidden key!
        for (int i = 0; i < n; i ++)
          string s;
          sprintf (s, "%s%-*s", line ? " " : "", Width , a );
          line += s;
        List += line + "\n";
      return List;
    // 2008-11-24 Christian Schlittler:
    // Make comma-serparated list, with all values double-quoted.
    string MakeListCSV (void)
      string List;
      int numHeaders;
      for (int l = 0; Lines[l]; l ++)
        string a [];
        if (l == 0)
          numHeaders = n;
        else
    List += "\"" + a[i] + "\"" + SeparatorString;
    List += "\n";
    return List;
    string MakeListHTML (void)
    string List;
    int numHeaders;
    List = "
    " + MakeListHeader() + "
    \n
    \n";
    List += "
    \n";
    for (int l = 0; Lines[l]; l++)
    List += "";
    string a [];
    if (l == 0)
    numHeaders = n;
    else
    if (l == 0)
    a[i] = "
    " + a[i] + "
    List += "";
    List += "\n";
    List += "
    " + a[i] + "
    \n";
    return List;
    string MakeList (void)
    switch (OutputFormat)
    case ofText: return MakeListText(); break;
    case ofCSV: return MakeListCSV(); break;
    case ofHTML: return MakeListHTML(); break;
    return "";
    void ViewList (void)
    dlgDialog (tr ("Bill Of Material - Preview"))
    string s = MakeList ();
    if (OutputFormat == ofText || OutputFormat == ofCSV)
    s = "
    " + s + "
        dlgHBoxLayout dlgSpacing (400);
        dlgHBoxLayout
          dlgVBoxLayout dlgSpacing (300);
          dlgTextView (s);
        dlgHBoxLayout
          dlgStretch (1);
          dlgPushButton (tr ("-Close")) dlgReject ();
    void SaveList (void)
      // 2008-11-24 cwi:
      // - Added new format extension .csv
      // - Changed from .bom to .txt for text format.
      string FileName;
      string FileExt;
        case ofText: FileExt = ".txt"; break;
        case ofHTML: FileExt = ".html"; break;
        case ofCSV:  FileExt = ".csv"; break;
      schematic(SCH) FileName = filesetext (SCH.name, FileExt);
      FileName = dlgFileSave (tr ("Save Bill Of Material"), FileName);
      if (FileName)
        string a [];
        if (!fileglob (a, FileName) || dlgMessageBox (tr ("File '") +
    FileName +
            tr ("' exists\n\nOverwrite?"), tr("+&Yes"), tr("-&No")) == 0)
          output (FileName, "wt")
            printf ("%s", MakeList ()); // using "%s" to avoid problems if
    list contains any '%'
    void DisplayHelp (void)
      dlgDialog (tr ("Bill Of Material - Help"))
        dlgHBoxLayout
          dlgTextView (language () == "de" ? HelpTextDE : HelpTextEN);
        dlgHBoxLayout
          dlgStretch (1);
          dlgReject ();
    schematic(SCH) {
      sprintf(SeparatorString, "%c", Separator);
      CurrentVariant = variant();
      SCH.variantdefs(VD) {
        if (CurrentVariant == VD.name) VDsel = cntVD;
        sprintf(Variants[cntVD], "%s", VD.name);
        cntVD++;
    setvariant(CurrentVariant);
    CollectPartData(CurrentVariant);
    GenerateList();
    dlgDialog (tr ("Bill Of Material"))
      dlgHBoxLayout {
        dlgLabel(tr ("Current &variant "));
        dlgComboBox(Variants, VDsel) {
          CurrentVariant = Variants[VDsel];
          GenerateList();
        dlgStretch(1);
      dlgListView ("", Lines, Selected);
      dlgHBoxLayout
        dlgGroup(tr ("List type"))
          dlgRadioButton(tr ("&Parts"), ListType) GeneratePartList ();
          dlgRadioButton(tr ("&Values"), ListType) GenerateValueList ();
          dlgCheckBox(tr ("List &attributes"), UseAttributes) {
            if (!UseAttributes) {
              NumParts = 0;
            GenerateList();
        dlgGroup (tr ("Output format"))
          // 2008-10-09: Entries swapped for correct function.
          dlgRadioButton(tr ("&Text"), OutputFormat);
          // 2008-11-24 cwi: New format added.
          dlgRadioButton(tr ("&CSV"), OutputFormat);
          dlgRadioButton(tr ("&HTML"), OutputFormat);
        dlgStretch(1);
      dlgHBoxLayout  {
        dlgPushButton (tr ("+Vie&w"))    ViewList ();
        dlgPushButton (tr ("&Save...")) SaveList ();
        dlgPushButton (tr ("H&elp"))    DisplayHelp ();
        dlgPushButton (tr ("-Close"))   dlgAccept ();
        dlgStretch(1);
        dlgLabel("Version " + Version);
    - - - - - - - - - - end of file.
    Robert Scott
    Hopkins, MN
