EAGLE User Support (English) How is this RGB Led strip connected
  • Subscribers 187 subscribers
  • Views 839 views
  • rgb led
xhendos
xhendos over 8 years ago
Dear Element14 community,
Recently I have bought this RGB LED strip. Once it arrived I have looked at the 2 datasheets of the components which it contains.
1) WS2811datasheet which converts a serial input signal to 3 parallel output signals (red, green, blue).
2) WS2812B datasheet which describes an individual LED.
The first thing that is remarkable is that both datasheets have different timing characteristics. For example to send a 0H in the WS2811 this requires 0.5 us HIGH voltage, but the WS2812B requires 0.4 us HIGH voltage to send a 0H. How are WS2811 and the WS2812B be able to communicate with eachother?
My other question is, how is the whole led strip soldered? As we can see on the website where I bought the strip, there are 3 female pins comming out of the strip. 1 is VDD and the other is VSS. The last that is left is data in. If I send data through my microcontroller to this data pin, I send data to the WS2811. Am I right?
The WS2811 produces 3 parallel outputs (red, green, blue), but the WS2812B LED contains only 1 data in? Why is there a need for individual colors if the LED can only take 1 data in?
I hope some experienced engineers can help me solving the question marks I have around this strip.
Kind regards,
Xhendos.
    0 autodeskguest over 8 years ago
    Am 03.11.2017 um 13:27 schrieb Youri Klaassens:
    Recently I have bought this (https://nl.aliexpress.com/item/30-60-144-Pixels-Programmable-Individual-Addressable-LED-Strip-Light-WS2812B-WS2811-Built-in-5050-RGB/32812945088.html) RGB LED strip. Once it arrived I have looked at the 2 datasheets of the components which it contains.
    1) WS2811 (https://cdn-shop.adafruit.com/datasheets/WS2811.pdf)datasheet which converts a serial input signal to 3 parallel output signals (red, green, blue).
    2) WS2812B (https://cdn-shop.adafruit.com/datasheets/WS2812B.pdf) datasheet which describes an individual LED.
    Kind regards,
    Xhendos.
    https://www.element14.com/community/message/230685
    Each of the RGB-Leds contains an WS2811 controller and its output is
    connected to the next controller (led) input. The Information of
    brightness is 8 bits for each colour thus 24 bits for 3 colours. The
    sequence is shown in the data sheet.
    Joern Paschedag
    0 shabaz over 8 years ago
    I think the 2812B incorporates the 2811 integrated circuit internally along with the three LEDs. There there are thousands of tutorials on these devices. There could well be discrepancies in the data sheets, these are "hobby grade" parts. Your best bet is to examine example code and example schematics from the hundreds/thousands of tutorials. If you have a strip then if the vendor has not provided enough information, it should be straightforward to visually see the supply and data in/out connections.
