EAGLE User Support (English) How to solve pin being overwritten by more than one signal errors in EAGLE PCB CAD?
  • Subscribers 187 subscribers
  • Views 2962 views
  • eagle cad
  • design error
  • eagle schematic
hiyalim
hiyalim over 8 years ago
I am relatively new to EAGLE and PCB Design. I am watching an online course and the tutorial goes through designing a PSU.
There are some errors that will be fixed later as the instructor informed. But I am facing these highlighted errors. That don't occur in the tutorial.
Can someone explain step-by-step on how to solve and why it happens?
I am attaching the schematic file as well.
Mohammad Al-Hiyali
    0 autodeskguest over 8 years ago
    Am 17.11.2017 um 02:31 schrieb Mohammad Al-Hiyali:
    Probably you placed a supply symbol (GND in this case) onto an existing
    net (i.e. you drew the net first an then placed the supply symbol). If
    you do that EAGLE asks you if the net should be renamed (to GND in this
    case). Except for very rare special cases you should answer "yes" to
    this question, because if you say "no", the net (and in your case the
    capacitors) won't be connected to GND.
    To fix these errors, just rename the nets in question to GND.
    And please use eagle.support.eng for questions like these.
    HTH
    Markus
    HTH
    Markus
    HTH
    Markus
    0 shabaz over 8 years ago
    Hi Mohammad,
    I'm not sure what you did, but it could have occurred perhaps if the supply symbols were renamed. By the way, some tutorials for EAGLE are not great, they have errors.
    Anyway, to learn, there is an excellent tutorial series here, and it is entirely accurate. Link to part 1 is below, and there are links to the remainder parts there too if you follow that link.
    EAGLE Tutorial: Library Part Creation Part 1 - Creating Packages
