EAGLE User Support (English) Checking unconnected pins in Eagle
  • Views 1808 views
avandalen
avandalen over 8 years ago
When manufacturing a large number of PCBs, you always will make one or more prototypes first. Imagine, you want to have your final Eagle project manufactured, but you want to make a few minor changes first. You have to be very careful now, because every mistake is disastrous, you don't want to throw away 1000 PCB's assembled with parts, and modifying is not a good option either.
A good way to final-check your Eagle circuit is to check the list of unconnected pins. You may have accidentally deleted a connection on the schematic during the last modification, and this will not be found with the Electrical Rule Check or Design Rule Check. Unfortunately, Eagle is missing a way to show a list of all unconnected pins. For this, I found a solution:
Determine the number of unconnected pins in Eagle:
Export in Eagle as text file:
  1. file> export Netlist
  2. file> export Pinlist
You now have two files:
  1. Netlist.txt
  2. Pinlist.txt
  3. Remove the unnecessary text in both files.
  4. Remove the empty rows in both files.
The number of unconnected pins is the difference in the number of rows in both files, this number must match the number of unconnected pins in the schematic that you have count.
I did this with Excel, with which you can automatically delete empty rows and see the number of lines.
WANTED: User Language Programs (ULP) for unconnected pins
It would be nice if a script was available for checking the unconnected pins, who can help?
Website: http://www.avdweb.nl/computer/eagle.html
  • avandalen
    0 avandalen over 8 years ago in reply to autodeskguest
    I use version 7.6.0. light, this doesn't show unconnected pins
    I will use a newer version, thank you!
    0 autodeskguest over 8 years ago
    1. Netlist.txt
    2. Pinlist.txt
    https://www.element14.com/community/message/231317
    Hi
    Which version of Eagle are you using?
    I use v7.7 and when I export the Pin List it tells me which pins are
    unconnected like so;
    Part     Pad      Pin        Dir      Net
    V1       1        Y          oc                *** unconnected ***
    If there is a chip with an implicit power connection but no matching net
    name, the Net list won't show a sheet number so you can tell if a power
    pin is missing a connection, like so
    Net      Part     Pad      Pin        Sheet
    +UB      V1       14       +UB        * none *
    Using the ERC I believe I can deduce all the wiring issues.
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
