EAGLE User Support (English) How do I remove all pin names in a selfmade library?
  • Subscribers 189 subscribers
  • Views 988 views
mrbertonio
mrbertonio over 8 years ago
I just made my first library in Eagle. It's for a pcb mounted 5x20mm fuse holder (http://www.littelfuse.com/~/media/electronics/images/fuse_clips/littelfuse_fuse_clip_105_125_image.jpg.jpg). So I made the package and symbols, and removed all names of the pins. The problem is when I place the component in my schematic, some text pops up. This reads '@1*2', since I numbered the pins of the package 1 through 4(1 & 2 and 3 & 4 are connected).
My question is: How do remove these names from my part?
Thanks in advance,
MrBertonio
  • mrbertonio
    0 mrbertonio over 8 years ago in reply to rachaelp
    Thanks! That worked out just how I wanted it to!
    The first online community specifically for Engineers.
    <http://www.element14.com?CMP=e14notificationemail_header>
    Login <https://www.element14.com/community/login.jspa?ICID=hp-login>
    Topics
    <https://www.element14.com/community/places?ICID=email_header&CMP=emc-e14notificationemail_header>
    | Resources
    <https://www.element14.com/community/places?filterID=all~tag[resources]&ICID=menubar_resources_all?CMP=e14notificationemail_header>
    | Content
    <https://www.element14.com/community/content?ICID=email_header&CMP=emc-e14notificationemail_header>
    | Design Center
    <https://www.element14.com/community/community/designcenter?ICID=menubar_designcenter?CMP=e14notificationemail_header>
    You have been mentioned
    by rachaelp
    <rachaelp> *in
    Re: How do I remove all pin names in a selfmade library? in element14
    Community* - View rachaelp's reference to you
    <https://www.element14.com/community/message/232110/l/re-how-do-i-remove-all-pin-names-in-a-selfmade-library?et=notification.mention#232110>
  • rachaelp
    0 rachaelp over 8 years ago
    Did you number your pads @1, @2, @3 and @4?
    What this means is on the particular pin where that text is found you have mapped pad @1 and one other pin for a total of 2 pins. You can turn this off in the symbol editor by going to the properties for the symbol pins and setting 'Visibility' to 'Off'.
    Best Regards,
    Rachael
