EAGLE User Support (English) Path Error - ULP to generate BATCH to generate CAM data
  • Subscribers 189 subscribers
  • Views 714 views
  • apostroph
  • ulp
  • blank
  • batch
  • path
  • eaglecon
  • quotation marks
  • gerber
slotis
slotis over 8 years ago
I'm preparing an ULP which generates a batch file which again generates with "eaglecon" all the Gerber files.
So far it worked well, but now I changed the location of my EAGLE project to a path which contains blanks.
Here my code:
eaglecon -X -N- -f- -O+ -c+ -dGERBER_RS274X -o ProjectName-TopCopper.gbr 'C:/10 - %BOARD_PATH%' %LAYERS%
eaglecon -X -N- -f- -O+ -c+ -dGERBER_RS274X -o ProjectName-TopCopper.gbr "C:/10 - %BOARD_PATH%" %LAYERS%
The reference manual says on page 335: "Paths which contain blanks has to be surrounded with apostrophes."
In both cases I get the error message: "Cannot find "C:/10". So it seems that the "eaglecon" command cannot handle blanks in the path.
Does anyone have an idea to solve this?
THANKS!
To prevent this question: NO, I cannot change the directory name image
  • slotis
    0 slotis over 8 years ago in reply to rachaelp
    Finally I could get it working.
    The correct way is to surround the path with " quotation marks ".
    My problem was that I had some more lines in the code where I didn't add the quotation marks.
    Thanks anyway for your help!
  • rachaelp
    0 rachaelp over 8 years ago
    Hi Stefan,
    When you write out your batch file from your ULP, you should try escaping the spaces with a \ character. So instead of the above example you would have:
    eaglecon -X -N- -f- -O+ -c+ -dGERBER_RS274X -o ProjectName-TopCopper.gbr 'C:/10\ -\ %BOARD_PATH%' %LAYERS%
    Best Regards,
    Rachael
  • dfgfdh
    0 dfgfdh over 8 years ago
