EAGLE User Support (English) Eagle 8.5.1 Air Wire Errors
  • Replies 11 replies
  • Answers 2 answers
  • Subscribers 190 subscribers
  • Views 5068 views
rarndt
rarndt over 8 years ago
With Eagle 8.5.1 I have air wire errors that I can not figure out how to correct (see attached).  I am modifying a PWB created in previous Eagle version, by adding one tri-color LED.  Both pins 1 (Din) and 2 (VCC) of the LED show air wires, and it is so small that I can't zoom in to see it.  Pin 3 (GND) routes fine to the GND polygon.  I have tried re-routing these two lines many times, with exact same results.  This LED is the only thing I have added to this board using Eagle 8.5.1.  Guidance please.
  • rarndt
    0 rarndt over 8 years ago in reply to rachaelp
    Thank you.
  • rachaelp
    0 rachaelp over 8 years ago
    As a follow up, Autodesk have released a bug fix release 8.5.2 which can be found here.
    This release fixes the known airwire issue and also an issue with incorrectly highlighting nets and showing them on other pages when adding to an existing net.
    Best Regards,
    Rachael
  • rarndt
    Thank you...
  • rarndt
    0 rarndt over 8 years ago in reply to dukepro
    Yes, this did correct the problem.  It does make group move not work, since then grouping selects the nearest component rather than allowing you to select a group of components.
  • dukepro
    0 dukepro over 8 years ago in reply to rachaelp
    On 01/02/2018 06:06 PM, rachaelp wrote:
      wrote:
    I guess it's time for me to retire from the news groups into reclusion, where the only company I have is v7.
    No!!!! Still lots of v7 and earlier users and a lot of your expertise is still very relevant for v8 issues! Definitely not anywhere near time for you to retire from here image
    You should give a recent freeware version of v8 a try if you haven't already. They now have Push&Shove and also integrated SPICE simulation. It's improving a lot.
    Sounds nice.  However, until they provide a perpetual license, and time
    I spend exploring v8 is a waste.  Much of the work I do is on a secured
    network, and I can't be plugging machines into the Internet just so that
    Eagle can phone home - whether it's once every 14 days, or once a year.
    Can't do it.
    I expressed to Jorge some time ago my position.  Many of the new
    features in v8 are very attractive to me, and I would love to explore
    them.  But until the licensing issue is fixed to our satisfaction, it's
    pointless.  Right now, I think that Autodesk will never provide this
    option, which means that when the time comes that our needs dictate more
    functionality than what v7 has to offer, I will have to exclude v8 from
    the qualification process.
    'nuf of that whiney license stuff.
    As far as hanging around, I'll continue to monitor the newsgroups until
    Autodesk retires them.  Since they would rather steer their users to the
    web with all the non-Autodesk crap that gets loaded, the NNTP servers
    probably won't be around much longer.
    What a bleak outlook.  This sucks, doesn't it?
    0 autodeskguest over 8 years ago in reply to dukepro
    Am 02.01.2018 um 23:26 schrieb Chuck Huber:
    On 01/02/2018 10:13 AM, rachaelp wrote:
    Hi Chuck, in EAGLE v8 (not sure the specific version it became available), you don't need that catch factor trick anymore as airwires have a section in DRC so you can find them easily by clicking on them in there.
    Well, THAT's an improvement.  I've manufactured at least one design that
    still had an air wire.  I hope the didn't remove existing functionality.
    Sayonara,
        - Chuck
    Hi Chuck I am on V6 and stay there.
    Stay here your valuable advices are always welcome.
    Joern Paschedag
  • rachaelp
    0 rachaelp over 8 years ago in reply to dukepro
    Hi Chuck,
    dukepro  wrote:
    Well, THAT's an improvement.  I've manufactured at least one design that still had an air wire.  I hope they didn't remove existing functionality.
    Nope, the existing functionality is still there :-)
    Best Regards,
    Rachael
  • dukepro
    Sayonara,
        - Chuck
    1651.att1.html.zip
  • rachaelp
    Hi Richard, This was reported on the main Autodesk EAGLE forums just before Christmas. They've identified the cause now I believe and it'll be fixed ASAP.
    Best Regards,
    Rachael
  • dukepro
    On 12/30/2017 10:28 AM, Richard Arndt wrote:
    With Eagle 8.5.1 I have air wire errors that I can not figure out how to correct (see attached).  I am modifying a PWB create in previous Eagle version, by adding one tri-color LED.  Both pins 1 (Din) and 2 (VCC) of the LED show air wires, and it is so small that I can't zoom in to see it.  Pin 3 (GND) routes fine to the GND polygon.  I have tried re-routing these two lines many times, with exact same results.  Guidance please.
    https://www.element14.com/community/message/232872
    Richard,
    From the board layout editor, go to Options -> Set -> Misc and set the
    Catch factor to 0.
    Then, start a route (Edit -> Route), and click anywhere in the layout
    editor.  The nearest air wire will start to route.  Move the cursor
    around and zoom in and out to locate the air wire.
    By setting the catch factor to zero, the Route function will pick the
    nearest air wire without limitations on how far that air wire is from
    the click location.
    Hope this helps,
    - Chuck
    8585.att1.html.zip
