EAGLE User Support (English) Eagle CAM Processor and Vias
  • Answers 2 answers
  • Subscribers 189 subscribers
  • Views 1597 views
phased
phased over 8 years ago
I am working on a 2-layer PCB design which uses devices with
pads on the top layer that connect to pads (edge card fingers) on the bottom
layer. According to the book I have (Make Your
Own PCBs with EAGLE: From Schematic Designs to Finished Boards
), the VIA
command is something to avoid. Mr. Monk says that just making the connections
between layers (as I have done) should cause Vias to be created automatically.
However, after running the CAM processor, I see no drill file as I would expect.
Am I missing something?
Thank you very much in advance!
  • phased
    0 phased over 8 years ago in reply to phased
    Hi Rachael,
    I know it has been several days since my last reply but it has taken me a while to get back to this project. I did find the file you mentioned called 'excellon.cam' and ran it. I thought it curious that it did not create a file with a .txt extension as indicated by the book I have as well as a youtube video tutorial that I watched. Anyway, I zipped up the gerber files and submitted them to a manufacturer. When attempting to do this, I got the following failure messages:
    Your project doesn't contain a bottom copper file.
    Your project doesn't contain a bottom solder mask.
    We couldn't find a drill file.
    We couldn't find a board outline file.
    So, based on this, I think it's fair to conclude that all the pads (copper), etc. are rendered only on the top layer. When I created the package for the edge connector (fingers), I put 8 on the top layer and 8 on the bottom layer. My first question to you, then, is how to switch the layer from top to bottom for 8 of the pads of this device on the board layout?
    The next question is how to go about creating a bottom solder mask once I have a distinct set of copper pads on that layer?
    And finally, from what I have read, it sounds like the geometry for the board outline needs to be created on layer 20 (Dimension). Is this true or is there some other explicit procedure for creating the board outline?
    Troy.
  • phased
    0 phased over 8 years ago in reply to rachaelp
    Hi Rachael,
    Thanks much for your reply and the information! I will be upgrading soon.
    Troy.
  • rachaelp
    0 rachaelp over 8 years ago
    Hi Troy,
    I'd recommend you move up to the latest version of EAGLE as there are lots of improvements in 8.4 (integrated SPICE, Live DRC, Flip board view), 8.5 (Push and Shove routing), and 8.6 (New CAM processor and Manufacturing flyoff) so the update is definitely worthwhile. The new CAM processor will deal with things a little differently, there are YouTube tutorials on the Autodesk EAGLE channel which will explain what's changed, but the outputs are much more efficient and use proper polygons rather than raster fills for polygons so it's a much faster export. If you stick with your current version or go for a version earlier than 8.6 then the excellon.cam file is in the %EAGLEDIR/cam folder which is part of the installation.
    Best Regards,
    Rachael
  • phased
    Hi Rachael,
    Sorry, I misspelled the name of the file (should be excellon.cam, of course) in my previous post.
    Thanks.
  • phased
    Hello Rachael,
    Thank you very much for the quick reply! I have version 8.3.2 of Eagle.
    Would you suggest that I upgrade the version I have or can you point me to a download of the excellon.com file?
    Thank you,
    Troy.
  • rachaelp
    Hello Troy,
    Just for completeness can you confirm what version of EAGLE are you running?
    However, the problem is likely because the generation of drill files is by a separate CAM process which isn't included as part of the default CAM jobs. You will need to load the job called excellon.cam and run that and it will create your drills file. In my setup I have combined the Excelllon drill job into my main CAM's so I don't have to run two separate jobs. I'm not entirely sure why anybody would want them separate.
    They have changed the CAM processor in 8.6.0 and the drill generation is included in the sample template CAM jobs.
    Best Regards,
    Rachael
