EAGLE User Support (English) Hatched ground with PCB_Gcode
  • Subscribers 187 subscribers
  • Views 266 views
rdagger
rdagger over 8 years ago
I've created a PCB with capacitive touch and it uses a cross-hatched copper pour. Unfortunately PCB_Gcode converts the hatched ground to a solid ground. Is there a way to get PCB_Gcode to retain the cross-hatched setting?  If not, is there another solution to convert the PCB to G-Code which supports cross-hatched grounds?
