EAGLE User Support (English) Eagle Lite Board Size Question (again)
  • Views 688 views
prairietech
prairietech over 8 years ago
I have a board with coordinates 0.00,0.00 when the cursor is in the lower left corner and 78.74,99.06 with the cursor in the upper right corner.
I placed all of my components jammed up inside the lower portion of the box that indicates the board size. None of the components is outside the line.
When I try and move any of the components toward the upper part of the board which is empty, I get the Eagle Lite limitation error message.
What am I not understanding about the board limitation of smaller than 80mm x 100mm?
  • prairietech
    0 prairietech over 8 years ago in reply to autodeskguest
    Now I get it. 100mm wide and 80mm tall. When I see specs of 80mm x 100mm I think width then height.
    I just figured it was about the square mm of the board and not the position the board is orientated in.
    0 autodeskguest over 8 years ago
    The maximum X coordinate is 100mm, maximum Y coordinate is 80mm.
    Anything you try to place above 80mm Y axis is is outside the limits.
