EAGLE User Support (English) How to make meander tool go in opposite direction?
  • Views 1060 views
mpiechotka
mpiechotka over 8 years ago
I have trouble figuring out meander tool. When I try to use it to match several signals (for example D+ and D- on USB) it adds additional patch only in one direction - causing one of the signals to bump into another. What am I doing wrong?
  • rachaelp
    0 rachaelp over 8 years ago
    When you have started the meander you can right click and it changes it between one side, and both sides. When it's set to one side you drag it to the side you wish it to go.
    One thing to note, if you are treating your USB signals as differential (which they are) then rename them to D_P and D_N and EAGLE will route them as a diff pair and the meander (if you still need it) will keep them as a pair and wiggle them together.
    Best Regards,
    Rachael
