EAGLE User Support (English) Eagle default library does not contain some packages
  • Subscribers 187 subscribers
  • Views 1200 views
digby
digby over 8 years ago
Hello. I am using Eagle 8.7.1 and working on the Eagle Version 8 Tutorial schematic( see Documentation ----> Tutorial_en.pdf), placing symbols using the 'add' icon from within the schematic. On p. 32 of said tutorial, it calls for placement of JP1 and JP2 from the pinhead library. These parts are PINHD-1X4 and PINHD-1X17.
The symbols are there for these parts, but the packages are missing.  In fact, most of the packages from the pinhead library are missing. However, if I open the library from the Eagle Control panel and select the pinhead library, the packages are there and I can drag them to the schematic.
Does anyone know why this behaves this way??
Thank you.
    0 autodeskguest over 8 years ago
    It's hard to say exactly, since it behaves correctly for me. What
    exactly do you mean by the packages being missing from the "add" dialog?
    When I try to add from that library, the entries in the list look like:
          PINHD-1X1      3D  PIN HEADER
       >  PINHD-1X2          PIN HEADER
       >  PINHD-1X3          PIN HEADER
       >  PINHD-1X4          PIN HEADER
       >  PINHD-1X5          PIN HEADER
       >  PINHD-1X6          PIN HEADER
       >  PINHD-1X7          PIN HEADER
    If I select the 1X4 then the package box at the top right is greyed out.
    Is this what you are seeing, and thinking it means the package is
    missing? If so, take a closer look down the left side of that list, and
    click on the expander arrow to the left of the part.
