EAGLE User Support (English) BOM for ordering parts
  • Replies 9 replies
  • Answers 4 answers
  • Subscribers 189 subscribers
  • Views 2653 views
  • digi-key
  • bom
  • element14
  • eagle 7.6
  • newark
  • ordering
fmarengo
fmarengo over 8 years ago
Dear Sir,
I am using Eagle 7.3.0 and need to buy the components listed in the bill of materials, which was obtained through the BOM.ulp command.
Which command do you recommend in order to obtain a complete list of components? My aim is to reduce the time I spend looking component after component with Newark/Digikey/Element14.
Thanks!
Fernando
  • fmarengo
    0 fmarengo over 8 years ago in reply to dukepro
    Dear all,
    Thank you for all your helpful replies. Do you happen to have any useful script for generating the BOM? The BOM.ulp command generates a table quite different from Mouser's requested format, which is like this:
    Mfr Part Number (Input)    Manufacturer Part Number    Mouser Part Number    Manufacturer Name
    The table generated via BOM.ulp looks like this:
    Qty    Value    Device    Package    Parts    Description    CASE    MANUFACTURER_PART_NUMBER
    I know it is possible to modify this table and make it look like Mouser's requested format, but I would like to avoid this boring stage.
    Thank you all.
    Fernando
  • dukepro
    0 dukepro over 8 years ago in reply to autodeskguest
    On 04/13/2018 08:39 AM, Rob Pearce wrote:
    On 12/04/18 20:57, Chuck Huber wrote:
    You should be able to save this as a CSV file from the BOM.ulp.  From
    there, you should be able to send the CSV file to a distributor as a
    BOM.  I know Mouser offers this.  Not sure about some of the others.
    Enjoy,
        - Chuck
    That depends on how well you've set up the BOM ULP database and/or the
    names/values/attributes of the parts in your design. But yes, in
    principle, the BOM ULP can export a CSV that can be arranged to include
    everything you need to upload to Mouser/Farnell/etc.
    Rob,  You're spot on.
    Sometimes I forget how well my setup works.  I combine the device and
    package name with the part's value to form an Eagle Key.  This key is
    then associated with one or more in-house part numbers.  By the "or
    more", I mean that we have multiple parts that have been qualified for a
    particular component, for example a "resistor, 1k, 1% 0603".  It's a
    freakin' jellybean.  Suffice to say that the Key will identify any of
    those qualified parts.  From each of the in-house part numbers, I pull
    the manufacturer (MFR) and the manufacturer's part number (MFRPN).  All
    this works in one step: "run bom".
    Some of the engineers present here (or used to be present), have chosen
    to push the part identification into the schematic by assigning
    attributes to each device/package in a library that include an internal
    part number or even an MFR and MFRPN
    When I saw this, I thought it was a pretty good idea.  But rather than
    include such attributes in a library, which would mean that every
    instance of that part would have the same attributes, I did a bit of
    programming in ULP, C, and php to provide a dialog box through which I
    could search a server-side database of parts.  With a right-click on a
    part in the schematic, a dialog box pops up and uses an HTTP based REST
    application to search for the part number in a database.  If a record
    from the DB is chosen by the user, then appropriate attributes are
    assigned to that instance of the part.  This allows me to differentiate
    between a garden variety 10k resistor and a 10k resistor that has a
    specific voltage rating or tolerance, or overload capability, or other
    special requirement.
    With whatever method you choose, the BOM.ulp can be modified to include
    the values of attributes in its output.  Attributes indicating MFR and
    MFRPN would be what Mouser/Farnell/Digikey would want.
    Enjoy,
        - Chuck
  • dukepro
    Enjoy,
        - Chuck
    Enjoy,
        - Chuck
  • dukepro
    Enjoy,
        - Chuck
    Enjoy,
        - Chuck
    0 autodeskguest over 8 years ago in reply to dukepro
    Enjoy,
        - Chuck
    On 04/12/2018 11:45 AM, Fernando Marengo Rodriguez wrote:
    Dear Sir,
    Thanks!
    Fernando
    Enjoy,
        - Chuck
    Dear Sir,
    Thanks!
    Fernando
    Enjoy,
        - Chuck
    Dear Sir,
    Thanks!
    Fernando
  • dukepro
    Enjoy,
        - Chuck
    Dear Sir,
    Thanks!
    Fernando
  • dukepro
    Enjoy,
        - Chuck
    Dear Sir,
    Thanks!
    Fernando
