EAGLE User Support (English) trace width ?
  • Subscribers 189 subscribers
  • Views 2627 views
  • eagle
  • trace
  • width
  • pcb
trace width ?
@xi@g@me
@xi@g@me over 8 years ago
Hello all,
I'm currently routing a project I made using eagle, but I'm worrying about the trace sizes I can use.
For DC power transport (I use a Myrra 240 - 5V transformer, with maximum of 900mA, which shall be largely sufficient) I use 10mil width and 12mil clearance traces.
For signal (basically the PCB I'm making is a SCART switch, so no much power is involved here, except perhaps for the 4 LEDs at the corners), I use only 2 mil (and 4 mil clearance, 5 mil via holes)
According to this web site, even 0.5 mil is large enough to transport up to 100 mA (again, the frequencies will be low, this is SCART), so I guess I'm OK by far.
By using default copper thickness in outer layers :
The site gives me this info :
But according to other threads I saw here and there, seems like I shall use 10mil thick (or 8 mils in certain conditions) instead.
So what are your thoughts about that  ? I have nothing against 10 mil traces, but 2 mils would be a lot better for me as I have 8 SCART inputs, which can make up to 64 parallel traces onto the PCB, which makes a huge difference...
  • @xi@g@me
    0 @xi@g@me over 8 years ago in reply to genebren
    Oh, that's good to know, I'll check that out immediately then. Now I understand why these limitations are in place ^^
    0 genebren over 8 years ago
    Greetings,
    The trace width calculator is a helpful tool to make sure that your traces can carry enough current, but as far as trace widths go there are over considerations.  First most PCB manufactures have a limit on the minimum width having to do with their processes and making sure that they can reliably build the boards.  Most PCB houses that I have used place this minimum between 6 and 10 mils.  Some PCB houses will charge a premium to build boards with trace below their posted minimums.
    Check with whoever will be producing your boards to see what their specifications are.
    Gene
