EAGLE User Support (English) Designate Pin 1 for manufacturing
  • Replies 9 replies
  • Answers 4 answers
  • Subscribers 189 subscribers
  • Views 2117 views
  • pcb manufacturers
  • pick and place
  • gerber files
joshjack
joshjack over 8 years ago
I've got a few custom devices on my PCB where I laid out the package (footprint) and schematic symbol myself.  On the footprint I have clearly numbered each pin to match the manufacturer's datasheets using the convention P$1 etc.  However when I generate the Gerber files and P & P files I have had 2 different manufacturers tell me they cannot tell where Pin 1 is on my footprints.
Should I be using something besides P$1 as a convention?  Is there somewhere else I should be designating a P1 so it is clear in the manufacturing files?
  • dukepro
    0 dukepro over 8 years ago
    https://www.element14.com/community/message/239733
    Joshua,
    In addition to the prior advice from Eagle experts, there are other ways
    of marking pin 1.
    Already mentioned by Eagle experts:
        - a dot or dimple in one corner
        - a square through-hole pad
    There are other methods worth mentioning as well:
        - a bar on the top surface near the end of a rectangular package
        - an angled corner
        - a beveled edge
    Take a look at the various packages in ipc-smd.lbr.  The packages
    publishes in that library//should be IPC standard and have IPC markings
    for pin 1.
    And they're right - get rid of the P$x crap that Eagle puts in there by
    default and number them properly.  Remember that BGA's will have both
    letters digits in their pad names.
    HTH,
        - Chuck
    On another unrelated note, I would eagerly welcome perpetual licenses.
    2844.att1.html.zip
  • dukepro
    Joshua,
    of marking pin 1.
        - an angled corner
        - a beveled edge
    for pin 1.
    HTH,
        - Chuck
    8664.att1.html.zip
  • rachaelp
    0 rachaelp over 8 years ago
    As others have said, name your pins properly (It wont help the manufacturer determine orientation in the Gerbers though) and for THT you can optionally set the pin 1 location to a different shape.
    But you should be providing this indication on your silk screen and in your assembly drawings. I wrote a library creation tutorial a while back. You can find the section on creating packages here: EAGLE Tutorial: Library Part Creation Part 1 - Creating Packages
    Best Regards,
    Rachael
    0 autodeskguest over 8 years ago
    Am 22.05.2018 um 18:27 schrieb Joshua Jackson:
    if you use THT then you can
    give the Pin1 an other shape.
    Pin1 shape "square"
    all others "round"
    HTH
    Werner
    Pin1 shape "square"
    all others "round"
    HTH
    Werner
    Pin1 shape "square"
    all others "round"
    HTH
    Werner
    In addition to what Joern says, the manufacturer is probably not
    expecting pin numbers on the silk screen (even if you're actually
    getting them). Check the datasheet for each of your ICs and you will see
    that there is a "pin 1 marker" somewhere on the chip, normally in the
    form of a dot or a dimple. You need to show that, or something like it,
    on the silk screen (or an accompanying assembly guide if the silk can't
    accommodate it).
    If you had a look at the delivered eagle libraries you would see that no
    SMD/PAD in the packages have something like P$1. (These Numbers are
    generated by default from eagle.)
    They have Numbers from 1 to... what ever image
    So just use the NAME command in  the  package editor to rename your
    smd/pads correctly.
    Then check in the device editor that the symbol pins are correctly
    connected to the package pads.
    Joern Paschedag
    smd/pads correctly.
    Joern Paschedag
