EAGLE User Support (English) Eagle board layout.  Reroute traces after component move
  • Views 890 views
  • autorouter
tremmert
tremmert over 8 years ago
I am sure this is a newbee question, but I have been searching and cant seem to find the answer...  I have completed the schematics and board layout, and all looked well.  I ran DRC checker, and no errors.
Next, I decided to rotate a component 180deg (9 pin header) and now I am failing the DRC check because of clearance problems and overlap problems.  When I try to run the autorouter again, none of the traces change on my board.  Isnt there a way to force the autorouter to run again and fix up these issues?
The only alternative that I have been able to find, it to delete the board files and start from scratch...
Thanks for the help.
  • tremmert
    0 tremmert over 8 years ago
    Using the RIPUP button.  I used CTRL-RightClick while having the Ripup Route tool selected.  Then I was able to run the autorouter again.
    Thanks!
