EAGLE User Support (English) Hello! I am trying to panelize y board. but I cannot paste the pcb to the panelize  pcb file that I made. Please help me.
  • Answers 4 answers
  • Subscribers 190 subscribers
  • Views 1063 views
hennessey12
hennessey12 over 8 years ago
Hello! I am trying to panelize a pcb. but I cannot paste the pcb to the panelize  pcb file that I made. The board just keeps on floating. I clicked on the paste button for a lot of times and  it is still not working. Please help me.
  • mario02
    0 mario02 over 8 years ago in reply to janice
    Normally the PCB manufacturer will help for that ,I once got help from ALLPCB, and that's quite convenient for my assembly work !
  • janice
    0 janice over 8 years ago
    Why do you need to panelize the paste files, if stencil is required for your boards, you can send indiivudl paste file and panelized outline to the fab.
    They can panelize for you ,and fabricate required stencil that matches your design ( That's how we work on ALLPCB.COM).
    If the boards need to  be panelized, we can just use individual paste file and panelized outline, then the stencil can be created correctly .
  • snidhi
    0 snidhi over 8 years ago
    One way is to chose your panel as the pcb outline/border and then draw milling cut out into it and copy paste the cut-outs across the panel.
    Thats how I am used to doing it. Make a new project select the panel as the pcb outline and put the mini-pcbs in there
    0 autodeskguest over 8 years ago
    a left mouse click should drop the floating copy
    Lorenz
    0 dougw over 8 years ago
    I'm not sure if there is a better way to panellize, but you can select the whole group to be pasted (Copy Group) and paste it anywhere.
