EAGLE User Support (English) Re: Autorouter not using new part
  • Subscribers 177 subscribers
  • Views 172 views
rcasteel wrote:
I think I have found the issue, but I don't know how to correct it.
When I made the new part, I placed holes where the pins drop through the
board.  I then placed pads around the holes using the auto setting for the
pads.  ow each hole has a ring around it in the Dimension layer.  Did I do
this wrong?
You place either a hole or a pad, but not both.
Holes should be used for simple locating pins or screw holes and use a pad
if the mounting pin will be soldered
The problem is, I cannot get rid of the dimension.  I can delete the hole
and the dimesnion stays.  Could this be what is causing this issue?  How do
I get rid of the Dimension?
Turn off all layers except the problem layer.
I guess you want to display the dimension layer, 21 and the holes layer 45.
Group and delete the holes.
cheers
David
