EAGLE User Support (English) Trying to decide whether to buy linux or windows license
  • Subscribers 178 subscribers
  • Views 370 views
I am trying to decide whether I should buy a linux license or a windows
license for eagle. I really want to use eagle under linux, but I have a
few concerns:
- I am using gentoo linux. This linux distribution is moving quite fast
  and so I am updating the distribution quite often. So, three important
  external dependencies of eagle will change quite often, which are
  Xorg, the linux kernel and cups printing system. I am afraid that
  eagle will stop working at some point in the future because of an
  incompatibility. What kind of experiences did the community have in
  this regard? Are the developers of eagle keen to make eagle work with
  the new versions of the X windows environment and the kernel? Or is
  there a "recommended linux distribution" and with any other linux, you
  are on your own?
- Manufacturers of printers tend to focus on developing windows
  drivers. I am afraid I will run into limitations and issues regarding
  to printing when I use the linux version.
I would hate to have to use eagle under windows, so I hope to hear that
I don't have to worry about the above ...
Timur Aydin
    Timur Aydin wrote:
    few concerns:
      are on your own?
    I've been using Eagle on Gentoo for over three years. At least one major KDE
    upgrade, the big Xorg 7 switch, etc. The only issue I've ever had was with
    the accelerated open source radeon driver for my ATI 9200 video card
    causing some font-rendering and polygon fill rendering issues--mostly fixed
    by tweaking the acceleration settings in xorg.conf. Never had a printer
    problem with CUPS and Eagle. I believe Eagle statically compiles most of
    the code, so there aren't many library dependency issues to trip you up.
    Compared to nightmare apps like Xilinx ISE--which I eventually had to run
    on a CentOS virtual machine--Eagle has been a dream.
    Timur Aydin wrote:
    few concerns:
      are on your own?
