EAGLE User Support (English) PDF printer ULP?
  • Subscribers 178 subscribers
  • Views 435 views
PDF printer ULP?
malevil
malevil over 17 years ago
Hi Everybody!
I would like to get a ULP program, to easily print out my sch/brd designs!
Separet layers to separet pdf pages. Is there any familiar ULP/script for
the Eagle?
Thank you!
Zoltan
ps.: I know the PDF printer method! It's still slow for us, hundreds of
designs need to be converted.
  • WestfW
    WestfW over 17 years ago
    the Eagle?
    You can use the CAM processor to output postscript, after which there
    are a bunch of utilities that can convert postscript to PDF.  The CAM
    processor has the advantage that you can invoke it from something like
    a shell script, which makes it ideal for doing this sort of operation
    on large numbers of files.
    For instance, I wanted a bunch of sort of silk-screen-like postscript
    files for panelization fiddling, so I made a c-shell script containing:
        /Applications/EAGLE-X11/bin/eagle -X -N -deps -o$1:r:t.otl.eps
    $1:r.brd dimension tplace tnames tvalues tdocu
    And then I was able to put together a bigger shell script with an
    editor that went through all the files I was interested in to generate
    the .eps files for all of them.  (If you're better at shell scripts
    than I am, you can probably do away with the "editor" phase.)
    BillW
