EAGLE User Support (English) Can't use layers
  • Replies 10 replies
  • Views 2306 views
Can't use layers
I have a schematic & board that was created using Eagle Light on linux.
I just upgraded to standard to be able to use 4 layers. I changed the
drc layers tab to ((12)+(1516)), but the layers are still not
available in the "display" or "select layers" areas.
If I create a new board using standard and set the layers to
((12)+(1516)) it works as expected. Is there a problem moving boards
create under Eagle Light to Eagle Standard? Or am I missing something?
-Brad
    Robert Pearce wrote:
    Greetings Martin van den Nieuwelaar,
    on Fri, 14 Mar 2008 you wrote saying :
    Really, when you can click and drag and find all the options you need
    under a menu like any other windows based interface, why would you
    bother to learn the extensive command line interface?
    Because, as I keep having to tell people whose computer experience has
    been crippled by Windows, the command line is very much faster and more
    powerful for a lot of jobs. This doesn't just apply to Eagle - it's true
    of lots of stuff from the *nix shell to text editors.
    I have observed people using CAD tools of all sorts, and computers of
    all sorts. In my experience, your "The GUI is BEST" cry is common among
    inexperienced to intermediate users. True experts prefer the greater
    power of a command line. Good software therefore provides both.
    Fair comment, and I think you're right too.  Perhaps what I should
    have said was "why would I bother to learn the extensive command
    line interface?".  The difference here is that I obviously don't use
    Eagle as much as you do, and I suspect never will; I will never be an
    expert Eagle user because I simply don't use it often enough.  If I
    take the time to learn the Eagle command line, that will be great in
    the short term, but I'm only working on a small/short project, so in
    six months or a year when I go to design another board I'll have
    forgotten a good chunk of it.
    What I'm trying to say is that it would be nice if the easy windowing
    interface didn't make the beginner and intermediate users move out of
    their comfort zones into the command line realm of the expert user (as
    was necessary in this case in order to get the two extra signal layers).
    For what it's worth I play on *nix systems all day on the command line
    and also use a text based editor for almost everything.  I still think
    it sucks though when a "GUI only" user runs into a problem where the
    solution cannot be found by way of the GUI and they have to use the
    command line.  The 'trick' I believe is to make the human-computer
    interface (whether Eagle, or any other software) usable by users of
    all abilities and without assuming that beginner users will eventually
    become (or even want to become) expert users.
    Sure, Eagle's command line by itself is a more awkward way to draw a
    schematic than the drag-and-drop approach. But when drawing new
    component packages in the library editor the mouse is a painfully slow
    way to place 64 pads on a regular and well-defined grid. Since I have
    some programming skill, it's much quicker for me to knock up a Python
    script to auto-generate the command line instructions into a .scr file.
    If I want to create (as I have several times recently) a whole family of
    connectors, then this approach does it in half an hour. It would take
    days to draw them all by mouse.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    autodeskguest over 18 years ago in reply to autodeskguest
    Brad Schick wrote:
    Ok thanks.
    Wouldn't it make sense for that to happen automatically when someone
    adds layers to a board that is running under standard or pro (even if it
    was create in Light and the layers don't exist yet)?
    My only real frustrations with Eagle are usability issues like this that
    are really all over the place. It would be nice if Cadsoft read posts
    like this one and along with providing a solution (which is
    appreciated), also thought "can we make this easier in the future
    without too much development effort".
    Don't get me wrong, I like Eagle and appreciate its value. But I wish I
    could spend less time reading the help files to do simple tasks. I'm
    happy to read help files for involved tasks.
    -Brad
    I strongly second Brad's comments!  We recently upgraded from the
    2-layer Light edition to the 4-layer Standard edition, and I thought
    I'd try out the 4-layer auto-router available in the Standard version,
    on the board I'm presently working on.
    I found in the autorouter setup window that only layer 1 and 16 were
    available, so instead I tried to manually route a track, but found the
    extra layers other than 1 and 16 I was expecting in the layer
    selection pull-down did not exist.  This satisfied me that it wasn't
    an autorouter issue per se.
    It didn't take long to figure out that I needed to specify the four
    layers in the design rules.  Alas after changing the edit->design
    rules->layers->setup field to (12+1516) I still didn't have access
    to the new layers.  What then?  Well I looked at the online FAQ, but
    found nothing.  Then I looked through the (printed) manual, but still
    found nothing helpful.  The CADSoft website mentioned these newsgroups
    as a good place to get support, but it turned out our company firewall
    blocks newsgroup access (TCP port 119).
    So while waiting to have the firewall rules changed I decided to try
    creating a new PCB.  This new board did in fact have all four layers
    available for routing (yay!).  I suspected it would, having thought
    about ways in which such an error could occur, as well as being a
    really switched on guy (and very modest too image).
    So next day I have newsreader access, and here I am.  Someone else
    with the same experience!  It feels so much better when you're not the
    only one pulling your hair out.  I tried the command
    Layer 2
    but that didn't work ('unknown layer 2' message).  Then I tried
    LAYER 2 Route2;
    LAYER 15 Route15;
    which worked a treat.  Now I have all the layers available that I
    expect, and the autorouter also lists them all.  Problem solved.
    Some things worth mentioning:
    I'm not a long time user of Eagle, and while it's clear it has evolved
    over the years from the bad old days when everything was entirely
    command line driven, that's not how I (and I suspect many other recent
    users) use it.  Really, when you can click and drag and find all the
    options you need under a menu like any other windows based interface,
    why would you bother to learn the extensive command line interface?
    So I know it purely from the windows based interface, and I baulk on
    those few occasions when I have to resort to the command line, such
    as with this layer business.  I believe that if there is a graphical
    interface, it should be possibly to do everything from the graphical
    interface.  Of course Eagle isn't the only example of this, one just
    needs to look at any graphical Linux distribution to find oodles of
    such flaws.
    I don't use Eagle every day, so I'd probably forget the commands
    pretty quickly anyway.  I know the odd package building/library step
    that's only possibly via command line and I have to look that up in
    the manual almost each time I do it (every few months).
    Suggesting 'help layer' as an obvious solution also isn't all that
    helpful; for a start I (and I suspect others) don't know what the
    'layer' command does, so there is no reason I would try typing 'help
    layer'.  Even if I did, the help really wouldn't help, because typing
    'layer 2' didn't work.  The help suggests that layer 2 and 15 should
    be available, but they aren't.  The help also talks about defining new
    layers, but tells you to use layers above 100.  I'm not even sure if I
    did define a layer above 100, whether I could use it for routing (just
    call it another one of those hunches).
    So yes, we like Eagle (I chose it for our next project, which is
    saying something), but it has some real quirks!
    If the authors wish to improve Eagle, I'd suggest they start by
    checking out some of Joel Spolsky's articles at www.joelonsoftware.com
    as he (IMNSHO) has some great ideas for making software more usable.
    Then again, maybe the authors are all German and don't hang out in the
    English newsgroups and never even see this discussion - vielleicht
    sollte ich eine Uebersetzung machen..?!
    David Moodie wrote:
    The command to add and delete layers from the menu is
    Layer 2     to add it
    Layer -2       to remove it.
    Note that they may not appear in order and could be at the bottom of the
    menu.
    And thank you for the assitance!!
    -Brad
    David Moodie wrote:
    Brad Schick wrote:
    In this case the help in eagle does work.  If you had tried HELP LAYER
    in the board editor you should have found the solution.
    Sure, but just because the answer exists doesn't mean its easy to find.
    I searched the entire manual for "Layers" and the only reference to
    that command was for changing layers, not creating them. Besides, I
    thought they would already exist if I defined them in the DRC.
    Its always easier to lookup the help for a command when you already know
    it exists and what it does in the first place image
    -Brad
    autodeskguest over 18 years ago in reply to Richard_H
    Richard Hammerl wrote:
    The board file was initially designed in the Light edition.
    This means that the inner layers are not gernerated, yet.
    Simply use the LAYER command now to generate them:
    LAYER 2 Route2;
    LAYER 15 Route15;
    Ok thanks.
    -Brad
  • Richard_H
    Richard_H over 18 years ago
    -Brad
    LAYER 2 Route2;
    LAYER 15 Route15;
    Richard Hammerl
    Brad Schick wrote:
    Ing. J.M. Rafetseder wrote:
    Try: set used_layers all, enter. See also the online help.
    No effect.
    I solved this by create a new board and then using the group-cut-paste
    trick to move everything over from the original board. I then closed
    everything and renamed the original board hide.brd and gave the new
    board the original name. The layers are all now available and
    consistency seems ok.
    Would be nice if the original problem was fixed for the future, however.
    -Brad
    Layer 2      to add it
    Note that they may not appear in order and could be at the bottom of the menu.
    In this case the help in eagle does work.  If you had tried HELP LAYER in
    cheers
    David
    No effect.
    -Brad
    e14 Contributor over 18 years ago
    r
