EAGLE User Support (English) How to set border limits for supply layers
  • Subscribers 179 subscribers
  • Views 365 views
Where do you set border limits for supply layers?
I just got some boards with internal supply layers (Vcc and Gnd) all the way
up to the border of the board, you actually can see the edge of the layer on
the board edge. Though the boards are ok a risk of a short circuit its big.
Rafael Fematt
    Rafael Fematt
    DRC, "Distance" tab.  The setting here sets the distance between the
    edge of a polygon or other copper and the Dimension of the board.
    John G.
  • Richard_H
    Richard_H over 17 years ago
    the way up to the border of the board, you actually can see the edge
    of the layer on the board edge. Though the boards are ok a risk of a
    Rafael Fematt
    John G.
    For polygons in inner layers okay, but for a supply layer (e.g. $GND)
    you have to draw a WIRE around the board near the border. Supply layers
    are displyed inverted, so your the WIRE is an isolation line.
    Richard Hammerl
