EAGLE User Support (English) Unable to Remove Part?
  • Subscribers 178 subscribers
  • Views 216 views
Greetings,
I created a new package, symbol and device which has raised an ERC error I
cannot eliminate, but Eagle refuses to let me remove the symbol from the
schematic editor.  I tried removing the library with the created component,
but the symbol still shows up.  When I use delete and click anywhere on the
part, a nearby component or net is removed instead.  Any suggestions?
Thanks!
RH
    Former Member over 17 years ago
    Did you remove the device in the lib?
    r
    r
