EAGLE User Support (English) hierarchy design
  • Replies 11 replies
  • Subscribers 180 subscribers
  • Views 760 views
hierarchy design
Hello All,
I've done a quick search through the newsgroups, but didn't find any thing
related to design reuse or a hierarchy design. I am new to Eagle and am
wondering if there is a way to reuse designs? I have a board with 4 copies
of the same schematic and some other schematics holding it all together. I
have copied and pasted the relevant schematics, however I would like to have
eagle place them on the board and route them based on a single board. Is
this possibe?
E
  • esilviu
    esilviu over 17 years ago
    there is no such thing like "hierarchy design" in Eagle, alltrough we all
    want-it.
    "E" <eveanema@gmail.com> wrote in message
    news:focea9$q0s$1@cheetah.cadsoft.de...
    Hello All,
    have eagle place them on the board and route them based on a single board.
    Is this possibe?
    E
    Former Member over 17 years ago
    "eSilviu" <Silviu.Epure@ugal.ro> wrote in
    news:focg5l$t24$1@cheetah.cadsoft.de...
    want-it.
    And there is definitely no way to get it in v.5 ;-((
    Jarda
    Hello All,
    thing
    copies
    I
    board.
    Is this possibe?
    E
    E wrote:
    Hello All,
    this possibe?
    E
    No. It would be nice to see some noises coming from Cadsoft regarding this
    and a few other major improvements
    The cheap and dirty work around is to start things off with only a single
    section and lay it out. This is then grouped, cut and copied into a new
    design as required.
    This is a slightly convoluted process. Go and look at a post from 23/1/2008
    from Mickey Reilley who has posted a reasonable summary of the process to
    copy this layout into a new design.
    cheers
    David
    Yes,
    seeing some kind of ACK from Cadsoft that a proposal was read and
    understood would make me feel easier. Matching the long list of proposals I
    made over the year with the V5 beta makes me worry which of these proposal
    will get implemented before I retire.
    It starts with multi-line texts.
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
    Yes,
    Absolutely
    Many years ago Cadsoft produced a roadmap when going from was it v3 to v4,
    and it was really good see that there was a definite path for development.
    As well as showing some concern for functions that users were looking for,
    it certainly made me comfortable to buy into Eagle for all our design work.
    V5 is not even out but I think it is time to dust off your list again and
    stick it up on user chat or suggest, say and see if we can get some response
    from Cadsoft as to where things are going to go, at least within 5.0-5.1-5.2
    sort of development frame.
    cheers
    David
    and stick it up on user chat or suggest, say and see if we can get some
    response from Cadsoft as to where things are going to go, at least
    within 5.0-5.1-5.2 sort of development frame.
    cheers
    David
    Agreed. I'm quite surprised Eagle hasn't outlined a dev path... And
    their response level to many of the good user suggestions isn't
    encouraging IMO... It's nice to see progress being made, but there are
    some really important basic things that need to be addressed which
    haven't been. I won't re-list any here, but they've been talked about
    many times.
    I'd like to see some sort of new feature polls, where payed users vote
    on new feature suggestions. After a few months, Eagle selects a couple
    of the top ranked suggestions that they otherwise had not intended to
    work on (either for that revision or ever) and seriously attempts to
    provide them for the next revision. I know I'm dreaming, but...
    Travis Grenell
    The CarPC Store
    404-403-0556
    http://www.TheCarPCStore.com
    "Travis G" <fightspammers@gmail.com> wrote in
    news:foghlf$ea7$1@cheetah.cadsoft.de...
    great idea! And vice versa there may be also list for not important features
    to indicate to CadSoft what users appreciate and what not.
    I vote for it!
    Jarda
  • esilviu
    ok
    who implement this, and where?
    I think one of us (users) should do this job
    "Jarda" <jarda@subcik.cz> wrote in message
    news:foh7su$f3q$1@cheetah.cadsoft.de...
    features
    I vote for it!
    Jarda
    eSilviu wrote:
    ok
    That's a very good question.  It is easy to propose these ideas image but
    implementing them, successfully, is another issue.
    As I see it there are two obvious routes
    a) set up some web based app that does it all. Providing a template for
    something similar already exists, sounds simple image but no doubt would take
    significant commitment from someone to set this up... any takers?
    b) do a quick and dirty version here. which would go something like
    1. establish a basic list to be used e.g.
    1. hierarchical schematics
    2. import dxf
    3. design re-use support
    4. teardrops
    5. explicit name for schematic sheets
    6. on the fly DRC for track spacing
    etc...
    2. users gets to make 3-5, say, (TBD) choices,
    and as long as everyone cuts and pastes from the original list, put in a tab
    say, then your prefernce,1-2-3- etc, e.g.
    1. hierarchical schematics     1
    3. design re-use support     2
    6. on the fly DRC for track spacing     3
    Then this can be cut and pasted into a spreadsheet and sorted by column for
    analysis relatively easily.
    Again this is just some quick thoughts on it, any other suggestions or
    alternative views would be good.
    Advantages of this approach
    quick (and dirty)
    open - everyone can see the data
    The guys at Cadsoft can see it... if nothing else it shows them that the
    users care and are concerned about the product.
    Does not require a great deal of effort from any single individual to set-up
    Can be analysed by anyone.. if cadsoft are interested they can do it..
    although I imagine there concerns lie elsewhere right now with the v5 release.
    Alternatively I'm sure there must be several of the university based users
    who have lots of time on their hands and could look after it all image
    In any event the first step is establishing a reasonable list of proposed
    improvements.  So any user (Uwe?) with a reasonable list who would be
    prepared to set things off and post their list?
    We should also take this probably to userchat for the moment, and then
    eagle.suggest when/if some conclusions can be established. Follups set to
    userchat.
    cheers
    David
    Discussion moving to userchat newsgroup.
    Travis Grenell
    The CarPC Store
    404-403-0556
