EAGLE User Support (English) freeDFM & via issue
  • Replies 19 replies
  • Subscribers 177 subscribers
  • Views 1587 views
freeDFM & via issue
I have a board I've submitted to freeDFM. Their error report for that board
is at:
.   https://www.freedfm.com/freedfm/0011385401921358/results/summary2.htm
The .brd file (only that file) I've made available at:
.   http://www.RGMEusa.com/Misc/USBto64RW.zip
I've already addressed all the issues not related to vias in another board
version, my only remaining problem is the one concerning freeDFM's complaint
about every one of the board vias.
If you look at the freeDFM error report it appears to my eye that all the
vias have no drill and they appear to all be filled in as if they were pads
instead of vias going through all 4 layers. I've also made available a
screen shot combination picture of the board concerning just one of the via
issues (the X=0.7641", Y=2.2966" example):
.   http://www.RGMEusa.com/Misc/SampleVia.jpg
It all seems ok to me so I haven't a clue as to why freeDFM is complaining.
In the combo screen shot I see it reports a drill for the example via as
0.015" and a diameter of "0.031/0.031 (auto)". I don't understand the
diameter syntax being used, meaning it looks to me like it is reporting 2
parameters separated by a "/" character. What is the definition of the 2
parameters which in the screen shot are identical to each other? If one
parameter is mathematically divided by the other the result is a zero value;
is THAT the reason freeDFM is complaining?
I need help understanding the nature of the problem and how to fix it. I did
generate the Execellon file while the board was displayed in the editor,
that's what was sent to freeDFM. TIA!
-Ron
    When I'm testing it I have just one DRC error with design rule
    www.my4pcb.com you have select !!!
    Guy
    PS: I'm affray, you don't use any condensators on this card !!!
    I think you must minimum add decouplers condensators to be sure work ok !!!
    "Ron" <viaEagleForum@RGMEusa.com> a écrit dans le message de news:
    fohhbe$6br$1@cheetah.cadsoft.de...
    is at:
    complaint
    pads
    via
    complaining.
    value;
    did
    -Ron
    is at:
    ..   https://www.freedfm.com/freedfm/0011385401921358/results/summary2.htm
    ..   http://www.RGMEusa.com/Misc/USBto64RW.zip
    -Ron
    I don't see any problem there. Lets see the Drill tab on your CAM
    project. I bet something is not selected in the CAM properly.
    Travis Grenell
    The CarPC Store
    404-403-0556
    http://www.TheCarPCStore.com
    is at:
    -Ron
    Ron
    Referring to "http://www.RGMEusa.com/Misc/USBto64RW.zip", I see problems
    that will cause your board to fail to work correctly:
    1) There are NO power and ground planes.  With a 4 layer board, usually
    the 2 inner layers are used for power and ground.  In  your case, this
    is VCC and VSS.  At the minimum, use a gridded power scheme.  Using
    copper flooding for GND (VSS) is also a good idea.
    2) I don't see any bypass/de-coupling and bulk capacitors.  There should
    be a 0.1uF ceramic bypass cap near each TTL and CMOS chip.
    Texas Instruments' publication # SZZA009 shows how to create a gridded
    power and ground system.  This doc also has other good ideas.
    HTH
    -Dave Pollum
    "Travis G" <fightspammers@gmail.com> wrote in message
    news:fohqsm$tdq$1@cheetah.cadsoft.de...
    board is at:
    board version, my only remaining problem is the one concerning freeDFM's
    complaint about every one of the board vias.
    pads instead of vias going through all 4 layers. I've also made available
    a screen shot combination picture of the board concerning just one of the
    via issues (the X=0.7641", Y=2.2966" example):
    complaining. In the combo screen shot I see it reports a drill for the
    example via as 0.015" and a diameter of "0.031/0.031 (auto)". I don't
    understand the diameter syntax being used, meaning it looks to me like it
    is reporting 2 parameters separated by a "/" character. What is the
    definition of the 2 parameters which in the screen shot are identical to
    each other? If one parameter is mathematically divided by the other the
    result is a zero value; is THAT the reason freeDFM is complaining?
    did generate the Execellon file while the board was displayed in the
    editor, that's what was sent to freeDFM. TIA!
    -Ron
    I don't see any problem there. Lets see the Drill tab on your CAM project.
    Travis Grenell
    The CarPC Store
    404-403-0556
    Hmmm. I don't think I have such an animal, Travis. I used the Excellon job
    while the project was loaded, per the manual. It just spat out the 2 drill
    files for gerber inclusion. I noticed theat one of the 2 files has a
    different filename suffix than what the manual specifies it should be, but
    freeDFM didn't complain about that (I don't think) so the format must have
    been ok? They looked ok to me (which means little). Is that what you want to
    see? If so, I'll have to put the Excellon file onto the server tonight after
    work. When I look only at layer 44, Drills, I see what appears to be overlap
    of drills but all vias are supposed to go through all layers and not some of
    them through just some layers, so that's giving me some confusion. Or do you
    mean you want to see the actual cam job, a modified GERBER_RS274X job? Gotta
    hold my hand a bit here, I'm not experienced enough yet to understand some
    things that in time will become crystal clear to me!
    -Ron
    Ron wrote:
      > Hmmm. I don't think I have such an animal, Travis. I used the
    Excellon job
    -Ron
    I'd like to see the actual job (ends in .cam) plus your generated drill
    files (usually .drd and also the .dri file) to compare everything, step
    by step.
    Travis Grenell
    The CarPC Store
    404-403-0556
    Agree with you
    Guy
    "Guy" <guy.dau_no_spam@free.fr> wrote in message
    news:fohqh1$sgn$1@cheetah.cadsoft.de...
    Guy
    Yes, that version had too tight of clearance for those 2 pins - I corrected
    that already. Annoyed me, as when I auto routed that one trace the DRC rules
    were not followed and I had to move the trace manually one grid away from
    IC1. Luckily, there is a DRC check button!
    Guy, this design (and the hand wired proto) definitely does not need VCC
    bypass capacitors. It's a state machine, no clocking, and the USB module
    (it's not a chip) includes its own decoupling to the USB buss; what that
    module connects to is not powered by the USB buss and it is rather slow and
    usually just sitting in one state. I do, however, need to (or should)
    increase distance between the Power class traces. I gotta rip again anyhow
    when I find out why freeDRM doesn't like the vias, I'll change the class
    then.
    -Ron
    "Ron" <Use@Forum.pls> a écrit dans le message de news:
    foicn5$rug$1@cheetah.cadsoft.de...
    Guy
    corrected that already. Annoyed me, as when I auto routed that one trace
    the DRC rules were not followed and I had to move the trace manually one
    grid away from IC1. Luckily, there is a DRC check button!<smile>
    and usually just sitting in one state. I do, however, need to (or should)
    then.
    -Ron
    No !!
    It's not because it's a state machine and no clocking then decoupling is not
    necessary !!!
    With all these circuits and not decoupling, alimentation can start in
    resonance !!!
    With many TTL and CMOS you don't know alimentation reaction !!
    I think you must define any bypass/de-coupling and after perhaps not
    necessary to put all but you don't know !!!!!
    After many years of electronic developpement.......
    Sorry for my english,
    Guy
    news:foiedu$vrq$1@cheetah.cadsoft.de...
    Guy
    anyhow when I find out why freeDRM doesn't like the vias, I'll change the
    class then.
    -Ron
    No !!
    not necessary !!!
    resonance !!!
    Guy
    This is getting way off topic but I do respect and appreciate your usage of
    English, please do not apologize. Although you could use a few less "!!!!!"
    characters!!!!!  You are understandable and if the situation were
    reversed I'd be, knowing only English, unable to return the courtesy.  But
    most of all I respect your knowledge.
    I would again try to qualify my agreement with what you say, which I believe
    to be a reference to a phenomenon known as parasitic resonance and which is
    a common annoyance in RF circuits. RF infers oscillation, and oscillating
    circuits have maximum power response at a resonant frequency.  My point is
    that there must be oscillation before there can be resonance, parasitic or
    not. This occurs in digital circuits primarily because of repeating patterns
    of current flow at high bit level changing rates (what I mean by "clocked",
    be it data pattern repetition or any other time base). The capacitive
    "decoupling" or "bypassing" is actually the detuning of the resonant
    circuit, dampening the amplitude of unintended oscillations to negligible
    level.  This is usually a very important consideration.
    But, if my design works (and the prototype does) and it experiences
    oscillations then it is malfunctioning because the amplitude of the
    oscillation would have to be of sufficient energy as to overpower the power
    supply as relates to the guaranteed high or low level specified for a gate
    input. If the power supply is working and distributed properly then that
    would have to be a rather huge amount of energy.  Without oscillation there
    can be no resonance.  If there can be no resonance then decoupling is not
    required.
    In this board all I/O is inherently latched. Even when changing at USB 2.0
    speed, the amount of time between cycles of a particular bit pattern that
    just happens to be resonant is what keeps enough energy from entering the
    tank to build sufficiently to overcome the power supply to a level where a
    gate would see a logic change. There simply aren't enough such cycles within
    a sufficiently small enough time period to build enough energy in a tank to
    sustain oscillation. If Murphy gets into the act regardless, then the
    mentioned time period can be lengthened by slowing down USB usage - thus
    detuning the tank.
    This board is an exception to the general rule that decoupling should be
    used. Primarily because it is latched and not clocked by some means.
    Repetitive tank pumping is not likely because repetitiveness does not exist
    in a latched circuit like it does in a clocked circuit. It would not hurt to
    use decoupling, except for production cost. My only worry with the entire
    design is that I might be exceeding the fan out rating of the USB module. If
    so, the resultant instability is not due to resonance or oscillation. On
    this board decoupling would be of little use, malfunction must begin before
    resonant oscillation can occur.
    -Ron
    news:foicb4$qva$1@cheetah.cadsoft.de...
    Agree with you
    Guy
    Ok Guy(s)! Have mercy. I don't deny it's good design practice but I'm not
    using the advice with this particular design. Please, I need to keep the
    topic focus to the subject line of this thread.
    -Ron
