EAGLE User Support (English) Schematic net connectors
  • Subscribers 177 subscribers
  • Views 352 views
In a schematic I'd like to visually connect Nets that are on opposite
sides of a drawing with little symbols. The symbols I often see in
datasheet schematics are usually a small rectangle with one or two
pointy ends indicating direction.
It seems like these must exists already, but I haven't found them in the
library or the docs yet.
-Brad
    -Brad
    Look in the "frames" library for the symbols, but you will have to add
    the signal names manually.
    John G.
    Thanks. Seems like a bit of an afterthought on Cadsoft's part. Any plans
    to improve this?
    I guess I'll add labels to the nets and move them near (or inside) the
    symbols so that they update automatically.
    -Brad
    Hi Brad,
    No work many on this because in new V5 you can set  XREF to "on" with
    "label" to do this !!!
    You can test it  ftp://ftp.cadsoft.de/eagle/betatest
    Guy
    "Brad Schick" <schickb@hotmail.com> a écrit dans le message de news:
    foj0lu$4lj$1@cheetah.cadsoft.de...
    to improve this?
    -Brad
    Good to hear!
    -Brad
