EAGLE User Support (English) Stop masks over holes
  • Subscribers 177 subscribers
  • Views 353 views
I have a few holes on my board that will be used for mounted. I added
the holes in the board editor, and they seem to have the top layer
stop-mask enabled. Seems odd since its going to be drilled. But either
way, how do I turn that off?
I clicked change, stop, off, then clicked on the holes but that did
nothing (fwiw, that seems to do nothing for the devices on my board either).
-Brad
    -Brad
    Stop mask layer show where the mask film is not applied. It applied
    after the board is drilled an may be silk screened. If you try to apply
    mask to the hole it can form a blob and drip.
    When you have a hole you can't put a stop mask on it.
    Paul R.
    Interesting. I considered that, but then doesn't solder get inside the
    hole? Or does it just not stick?
    -Brad
    -Brad
    apply mask to the hole it can form a blob and drip.
    -Brad
    If you want unplated holes you have to let the board house know that
    have to be drilled after plating. If you want to have plated holes but
    no solder on it when they are wave solder you have to tell the assembly
    house to apply solder resist to the holes which prevents the solder from
    reaching that area when it is run in the wave solder.
    Paul R.
