EAGLE User Support (English) Install eagle on lub
  • Subscribers 189 subscribers
  • Views 1008 views
  • lubuntu
  • ubuntu linux
  • error
  • linux
k@m
k@m over 7 years ago
Very new to the Lubuntu and Eagle community but early want to dive in head first. However, I am having some trouble installing eagle on by Dell laptop.
I'm getting the following error:
~/Downloads/eagle-9.2.2$ ./eagle run
terminate called after throwing an instance of 'std::runtime_error'
  what():  locale::facet::_S_create_c_locale name not valid
Aborted (core dumped)
Any one have any ideas as to what this means and or a fix?
  • Gough Lui
    0 Gough Lui over 7 years ago in reply to k@m
    If you see the error message:
    It gives us a good clue. On systems with no locale defined, the locale is often called 'c'. Hence, the error is complaining that attempting to create 'c' locale that the locale itself is not valid -> implying the locale is not supported and also telling us that you have no locale set.
    Glad to hear that setting the locale fixed it.
    - Gough
  • k@m
    0 k@m over 7 years ago in reply to Gough Lui
    Worked!
    How did you know to to solve this? I'm not sure what the error even means and or how it relates to the locales.
  • Gough Lui
    You may need to set your system locale - https://www.thomas-krenn.com/en/wiki/Configure_Locales_in_Ubuntu
    Make sure you set it to the correct locale for your country and one that is supported by Eagle.
    - Gough
