EAGLE User Support (English) Problems with Group Copy
  • Subscribers 178 subscribers
  • Views 414 views
I want to copy a group of objects in a schematic.  I do a GROUP
operation on the objects.  Then I do a CUT operation.  I do a PASTE
operation and when I left click on the schematic to paste I get a
warning that says "Skipped Unsuitable Objects" and nothing happens.  The
objects in question are a header connector, some nets and supply
symbols.  Can someone shed some light on why I am getting this error?
Cheers,
Nate L.
  • esilviu
    esilviu over 17 years ago
    because you could only cut/paste FROM-TO a schematic, or FROM-TO a board, or
    FROM-TO library.
    don't mess things!
    "Nathan Lowrie" <solodex2151@gmail.com> wrote in message
    news:fojkei$r3q$1@cheetah.cadsoft.de...
    I want to copy a group of objects in a schematic.  I do a GROUP operation
    on the objects.  Then I do a CUT operation.  I do a PASTE operation and
    when I left click on the schematic to paste I get a warning that says
    "Skipped Unsuitable Objects" and nothing happens.  The objects in question
    are a header connector, some nets and supply symbols.  Can someone shed
    Cheers,
    Nate L.
    FROM-TO library.
    don't mess things!
    I am copying FROM a schematic TO the same schematic when I get this error.
    Cheers,
    Nate L.
    Hello Nathan Lowrie !:
    Could you send us an example ?
    I am using very very often copying of schematic parts without any
    problems. The error what you get is typically a sigh for some elements
    in layer not dedicated for schematic.
    Of course you should have the sch layers switched on before grouping.
    regards
    Grzegorz Zalot
    complex ltd.
    office tel/fax : +48 32 2505840
    mobil : +48 501 301515
    http://www.complex.org.pl/
