EAGLE User Support (English) Maximal hole size
  • Subscribers 187 subscribers
  • Views 1680 views
  • drill size
Maximal hole size
SMD111
SMD111 over 7 years ago
I am using EAGLE 6.4.0 Professional. I discovered that the maximal drill size it allows to choose (either in a pad or in a hole) is 0.1285"
Why is there such limitation? How can I overcome it?
    0 autodeskguest over 7 years ago
    Am 19.12.2018 um 20:21 schrieb SMD111:
    Just enter larger values by hand.
    Up to 200 mm (7.7840") are valid, but it may be wrong in the help file
    for 6.4.0.
    You might want to update to EAGLE 6.6.0 (for which your license should
    be valid, too). There were quite a few bug fixes.
    From UPDATE_en.txt:
    Release notes for EAGLE 6.6.0
    • Miscellaneous:
       - Update in help for maximum sizes related to pads, smds, vias, wires,
         polygons and holes from 0.51602 inch to 200 mm and for board size
         from 1600x1600mm to 4000x4000mm.
    for 6.4.0.
    From UPDATE_en.txt:
    • Miscellaneous:
