EAGLE User Support (English) Odd Auto-Router error message
  • Subscribers 178 subscribers
  • Views 353 views
I am using the Standard version of EAGLE v4.16r1.  I have a 4-layer
board that is set up in DRC as (12+1516).  When I run the autorouter,
it displays this error message:
"Layer 2 (Route2), Layer 15 (Route15) used but not enabled!"
"Objects there may collide with vias placed by the autorouter"
Layer2 is a copper pour (polygon) named GND.  Layer15 has 3 different
copper pours.  I deleted the GND polygon, and created it again.  The
autorouter still complained.
How do I get around this???
-Dave Pollum
    -Dave Pollum
    Please check the the Layers selection in the Autorouter Setup Menu.
    Look into the "General" tab. What is set for the innner layers?
    "N/A" would be wrong.....
    Richard;
    I did have "N/A" set for the inner (polygon) layers.  When I changed
    them to "*", the autorouter worked OK.  Thanks!
    -Dave Pollum
    -Dave Pollum
    Richard;
    -Dave Pollum
