EAGLE User Support (English) How to solve the error : Part has only 1 gate: U$1
  • Views 1739 views
  • control card
  • pcb designer
  • motor drivers
  • schemeatic
  • eagle 9
  • error
  • invoke
jihene
jihene over 7 years ago
I'm new to using the Eagle software and I'm trying to design a control card for stepper motor and servo motor using a raspberry card on Eagle software.
The first problem is the errors that the software indicates, whereas for me, they are not errors because these pins are not connected in my original schema.
I checked others people questions on different forums with similar problems and professionals indicated that we should use the "invoke command" and connect the unconnected since Eagle works that way but when i apply that method, i get this message : "Part has only 1 gate: U$1"
The device that keeps showing me this error is " Polulu stepper driver based on the A4983" , i downloaded this device since i'm working with DRV8825 and it has the same design.
The second problem is when i switch from schematic to PCB design, The connection on this A4983 changes.
I don't know what's wrong with my design or what steps should i take to avoid this ? I have included 3 images : the design schema, the error and the connection route switch
Thank you for taking the time to read my post and answering it image
    0 autodeskguest over 7 years ago in reply to WarrenBrayshaw
    Am 14.01.2019 um 03:27 schrieb Warren Brayshaw:
    I searched using Google"  for "Polulu stepper driver based on the A4983" and I think I found the library you downloaded here:
    http://www.elfaforums.lv/attachment.php?attachmentid=6568&d=1447010306
    This has a device named " Polulu stepper driver based on the A4983"
    The device "connects" the pins of the Symbol  to the pads of the Package as you would expect but..the package used, "DIL16" , is built wrongly.
      Instead of the pads numbering around the package 1,2,3,4.....13,14,15,16 it has the pads named in this order around the package 1,2,3,4,9,10,13,14, 16,15,11,12,5,6,7,8
    So fix up that library and you will be on your way.
    Warren
    https://www.element14.com/community/message/270353
    Besides what Warren has said the package is NOT a common DIL16. I would
    rename it to DIL16-500 to avoid conflicts wit the common DIL16-(300).
    Joern Paschedag
  • WarrenBrayshaw
    0 WarrenBrayshaw over 7 years ago in reply to WarrenBrayshaw
    Warren
  • WarrenBrayshaw
    Hi
    I suspect the library you have downloaded for the stepper driver is faulty so check the library first. In the 'Device Manager'  confirm that the pins and pads are 'connected' correctly.
    You could post a link to where you downloaded that library so that others could inspect the library.
    HTH
    Warren
