EAGLE User Support (English) Orcad -> Eagle schematic
  • Subscribers 177 subscribers
  • Views 576 views
I've seen various comments around the web about translating between Orcad
and Eagle but there doesn't seem to be any consensus especially for
schematics. I need to translate an Orcad Capture Schematic to an Eagle
Schematic, can anyone recommend a way of doing this?
I've seen comments about going via DXF or Protel but I can't make out how
much information is actually transferred, is it just graphics or is it net
and parts information that is transferred? Basically I need to be able to
transfer to Eagle and then work further on the resulting Eagle schematic and
then create a netlist and layout a board. Any ideas?
Regards
Charles Sweeney
    "Charles Sweeney" <charles.sweeney@orangetreetech.com> wrote in message news:fosq0g$49v$1@cheetah.cadsoft.de...
    I've seen various comments around the web about translating between Orcad and Eagle but there doesn't seem to be any
    consensus especially for schematics. I need to translate an Orcad Capture Schematic to an Eagle Schematic, can anyone
    I've seen comments about going via DXF or Protel but I can't make out how much information is actually transferred, is it
    just graphics or is it net and parts information that is transferred? Basically I need to be able to transfer to Eagle and
    then work further on the resulting Eagle schematic and then create a netlist and layout a board. Any ideas?
    Regards
    Charles Sweeney
    I've done half of what your describing. Short of redrawing the Sch, theres no easy way.
    We kept the Orcad schematic (since I didnt have Orcad) and had the netlist exported.
    We also exported a parts list with package information.
    Imported the part info into excel.
    Created a excel macro that would create a scr to place the components on the board.
    Create all the library parts needed.
    Run the Excel generated scr to place the parts.
    Export a Multiwire netlist from Orcad.
    Then use the xconvert.exe in the eagle directory to convert the netlist.
    Then run the scr in eagle to connect the nets.
    The only problem that arises is when nets are changed, If someone flips pins on a component then the nets get crossed.
    Cheers
    On 2/12/08 1:54 PM, in article fosq0g$49v$1@cheetah.cadsoft.de, "Charles
    Hi Charles,
    Converting schematics from one form to another is tricky business.  There is
    a lot of information behind that and very few CAD packages want to allow you
    to move to another tool with no cost.  If they did, you'd have no reason to
    stay with any given platform and tool vendors don't like that.  And I can't
    blame them for wanting a more captive audience.  Doesn't mean I necessarily
    like it though.
    I don't know of any tool that will take a native orcad schematic and convert
    it to another format as a schematic.  It should be theoretically be possible
    (and maybe a tool does exist) but I would imagine that it would take a lot
    longer to develop the tool than just redraw the schematic.  The best I could
    suggest is to export the netlist and then import that into EAGLE PCB.  You
    could then rebuild the schematic and check the netlist until it matches.
    That way, you'd know it was the exactly the same.  Then use that as you go
    forward in development.  Not pretty, but it will work.
    If you do choose this path then check out the EET: PADS Interface tool I
    just released at the website below.  It will help you import the PADS
    netlist into the EAGLE PCB editor as a starting point.  And if you need help
    with the rebuilding then send me an email from the website.
    Cheers,
    James.
    James Morrison
    www.eagletoolkit.com
    Long-time EAGLE User and EAGLE Enterprise Toolkit Author
